Results 1 to 8 of 8
Thread: Welding thick to thin
16th Dec 2013, 03:18 PM #1
G'day all,
I want to weld a hitch receiver to the end of my camp trailer and have the dilemma of having to weld 6mm 65x65 SHS to 45x45 what I think might be 45x45 1.6 mm wall.
I have a unimig 180 and have never had this challenge before.
Any advice on what would be the best was to heat enough to penetrate the thick stuff but not blow a hole in the thinner?
Geoff
17th Dec 2013, 07:19 PM #2Member
- Jan 2012
- Brisbane
- 50
Keep the weld pool on the thicker metal then just dip the ark onto the thin stuff
17th Dec 2013, 08:36 PM #3
Thanks Rat.... should add that it's also a overhead weld
18th Dec 2013, 12:07 AM #4Member
- Dec 2012
- WA
- 68
Practice on scrap, and keep practicing.
18th Dec 2013, 05:31 PM #5Member
- Jan 2012
- Brisbane
- 50
I hate overhead welding, probably because I never do it. But as Aufitt suggested get some scrap and have a play around first
18th Dec 2013, 06:18 PM #6Senior Member
- Jul 2008
- 210
Turn the tailer upside down and the weld quality will improve enormously.
If you can't invert it try rolling it on one side.
18th Dec 2013, 09:20 PM #7
There's nuthin like laying under some hot weld spatter even with a hood and weld jacket!!!
I'm with zuffen and tip it if you can practically achieve this in the shop.
Dont recon you could get the heat into the 6 mm as fast with a sml mig than whats possible with an arc. Well not in my experiences anyway. Will admit to preheating with the arc away from the weld area and quickly switching to mig and welding.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
29th Dec 2013, 09:23 AM #8
If the Hitch receiver on the rear of the Camper is for carrying a bike rack, my concern would be the 1.6mm material of the Camper chassis, not your welding.
Even if you went to the trouble of turning the Camper over and getting a good weld penetration by keeping the weld pool in the thicker material like Rat said, the weight and forces of three or four bikes on the end of a bike rack constantly bouncing along an Australian road are huge. It won't be the weld that gives way, but the 1.6mm steel around it.
I would look at putting another length of chassis rail across the rear in 3-4mm material, stitching it to the original and to the side rails. I would even go as far as two more short lengths running longitudinally from this new cross rail to the next cross rail forward to allow welding of the rear of the hitch receiver. This 'T' frame could even be fabricated separately so as to get good weld penetration before slotting it under the Camper and attaching to the chassis.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
Welding Critique: SS 2mm Thick MIG
By Jarh73 in forum WELDINGReplies: 12Last Post: 24th Mar 2012, 04:54 PM -
Welding thick to thin section RHS
By Grahame Collins in forum WELDINGReplies: 1Last Post: 6th Nov 2007, 08:34 PM
