Results 1 to 7 of 7
13th Dec 2013, 02:48 PM #1
How to work out what weight to be carried
Hi,
Just wondering is there a method for working out what thickness wall and what dimensions steel I should use against the weight of the gear I want it to carry?
I'm thinking of making a boat rack for for my tinny to go on my camp trailer for trips away. I wouldn't know exactly how much the boat weighs, but I'm tipping somewhere in the 60-70kg mark and I'm just wondering what size steel tubing I should use to build it.
I want to build it with gussets in the corners for added strength also, and I'm curious if there is some sort of formula I could follow to help me select the outer dimensions of the tube and also the wall size?
Any advice would be greatly appreciated.
Geoff
13th Dec 2013, 06:41 PM #2Philomath in training
- 6,540
You might be better asking that question in the trailer section
TRAILERS & OTHER FABRICATED STUFF
13th Dec 2013, 07:58 PM #3Most Valued Member
Rather diagonal bracing that gussets.
I built a roof rack for a mates 4WD (roof top camper thingy).
I was never completely happy with the result. But at the time couldnt come up with an idea to fix it I was happy with either. I said I think it will be ok, but if its going to fail it will fail right there.... Well I was wrong and right
With some rope work he did manage to finish his trip(across one of the deserts) and get home, though by the time he got there 3 of the 4 joints I wasnt happy about had failed. Pitty that it was a good looking rack otherwise lol. They did say the roads were shocking....... but still.
So first thing to think about would be "where are you planning on going?"
16th Dec 2013, 01:41 PM #4
Hi Stu,
Just flat road and caravan parks mate.
18th Dec 2013, 08:59 PM #5
Of course how its constructed will have a bearing on things.
If it was me building it I would go for 40 x 40. 2mm wall would be plenty.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
18th Dec 2013, 10:53 PM #6
Thanks for the advice.
I was thinking 35x35 1.6 with a 30x30 1.6 to telescope the 35x35.
I was kind'a thinking I'd like to match something similar to the picture
18th Dec 2013, 10:55 PM #7
Or like this and add one of them baskets from ebay or supercheap auto with some U bolts
DOVETAIL COLUMN MILL DRILL- Work Table Weight
By steran50 in forum METALWORK GENERALReplies: 2Last Post: 22nd Sep 2009, 09:34 AM
