Results 1 to 8 of 8
Thread: Trailer Axle / spring help
8th Jan 2013, 05:12 PM #1New Member
- Jan 2013
- Nsw
- 3
Hi Im new to the forum.
Not sure if I am posting in right place but saw other trailer questions so thought id give it a go as I am stumped.
I have an old 15 1/2 foot clinker style ( full fiberglass ) speed boat with a 292 ford y block inboard engine and wanting to know the weight as need to replace the trailer's single axle and springs but due their condition I cannot drive it anywhere to weigh and dont want to just take off and replace with the same axle as it is bent so may be under sized . If anyone knows the rough weight it would be a great starting point.
8th Jan 2013, 06:56 PM #2
Our resident Guru/Go Guy(bloody Americanism) for everything to do with trailers is "Yonnee". He works in that field and has a wealth of real practical knowledge.
If it were me I would go for something quite "substantial" so you will be covered when the "what ifs" come into play
Oh and Welcome to the Forum. Hang on tight because its a ride that covers a lot of ground. So many people with so many interesting things going onJust do it!
Kind regards Rod
8th Jan 2013, 07:19 PM #3Senior Member
- Jul 2008
- 210
The cost differnece between a "she'll do" and a "she's good" axle is two thirds of bugger all so go the bigger axle.
I'd expect an all up weight of the boat to be around 750kg. Which techincally means it needs brakes.
8th Jan 2013, 09:44 PM #4
The heaviest part is the motor and from a quick search online, it weights approximately 280 kilos, I'd expect the hull to be 150 to 250 kilos and depending on trailer construction that'll be 200 or so kilos, so you could be looking anywhere from 600 to 900 kilos I'd imagine.
Best best is to hire a car trailer, weight it then put boat and trailer on car trailer and weight then subtract car trailer weight.Cheers
DJ
ADMIN
9th Jan 2013, 02:29 PM #5New Member
- Jan 2013
- Nsw
- 3
Thanks for the replys Guys , I just found this thread again after reposting another . I think I have to read the forum instructions as well
10th Jan 2013, 05:00 PM #6New Member
- Jan 2013
- Nsw
- 3
This is an old trailer and the slipper springs are 40" long from eye to middle of hanger and I can only seem to find 20" or 30" .
Do I need the hangers cut and re-welded to fit the smaller springs and if so would I get them welded 5" closer from both ends to bring them in 10"
11th Jan 2013, 11:33 AM #7
Hi Riks, and Welcome.
Can I say, Boat trailers are a PITA! Nothing but trouble, and big money pits...
Now I've got that off my chest, I reckon DJ's pretty close. Depending on construction, it could all vary by several hundred kilos. As Zuffen has said, the cost difference between a 1000Kg axle and a 1400Kg axle is bugger-all. It's the addition of brakes that really jump the price.
My suggestion would be to inspect your hubs first. If they're useable, then you can order a new axle in a Slimline (Ford) bearing pattern (this will give the biggest bearing/axle capacity), and then put new bearings in your old hubs. I would order the axle with Mechanical Disc brake mounts fitted to it as well (this will be bugger-all extra too). You can get springs made up, or you'll have to change the hangers. I would go 6 or 7 leaf springs (1200kg) because you can always remove a leaf or two if it ends up nowhere near that weight.
Then once you've got it rolling with its new axle/springs, you can take it to a weighbridge and then you'll know whether it needs brakes.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
2nd Feb 2013, 09:25 AM #8Intermediate Member
- Feb 2009
- ACT
- 42
Hi Riks,
I think you might be surprised how much those older style clinkers weigh, heavier than you think.
Once you fill it with juice, throw in the esky, all the ski gear, chairs etc etc, you'll be up around 1200kgs on the weighbridge. Easy.
You'll end up wishing it had tandem axles. I'd never buy another inboard on single axle.So many ideas........so little skill........
Trailer with Weird Axle Placement
By zuffen in forum TRAILERS & OTHER FABRICATED STUFFReplies: 17Last Post: 6th Aug 2012, 07:46 PM -
Widening a trailer axle.
By Vernonv in forum TRAILERS & OTHER FABRICATED STUFFReplies: 13Last Post: 25th May 2011, 07:42 PM -
How To Measure Axle Length & Spring Packs
By Bad Fruit in forum TRAILERS & OTHER FABRICATED STUFFReplies: 4Last Post: 18th May 2011, 08:48 AM
