Results 1 to 6 of 6
6th Jan 2013, 04:59 PM #1New Member
- Oct 2005
- 0
Alloy tray trailer / caravan chassis
Gday all,
I am about to start work on converting a large caravan chassis into a tray trailer. I will post pics as I go along.
But firstly, a few questions if I may. The chassis right now is stripped ready to go. Main frame and drawbar is 127mm x 51mm(??) and looks to be about 3mm so is well made and strong enough. I have already replaced the axles, wheels, coupling and has mechanical drums on the front axle so should be right for a 2 tonne rating. It also has roller rocker suspension.
I have purchased a large alloy truck tray that is about 4.5m x 2.5m as it was so cheap and could not go past it. Rails on this look to be about 800/900 wide. (Just waiting on the exact measurements). Chassis width on the trailer is 1700mm centred on the side rails. So looking at those measurements, this would mean that they current tray rails would be sitting in about 400mm from the current side rails.
If I was to weld in cross members (4 or 5 of them) in between the side rails that are the same size (127 x 51), and then mount the tray to these, would this be strong enough to take the load on the tray.
I also have a large truck box that is 1mtr square (on the end with a door in each end) and 1.8m long that I was going to mount on the frame in front of the tray. This would weigh about 125kg. I have read about placement of the axle being 1/2inch to the rear for every foot of length. Can I incorporate the box into this measurement too or should I just use the length of the tray for the axle placement. I am a bit concerned about drawbar weight with the box.
I hope this makes sense.
Krico
6th Jan 2013, 08:07 PM #2
I built one of those some years back. 14' x 7' tray 8' across teh wheels. We split the tray and infilled the area between the wheels with timber to get the lowest tray height.
I've had numerous people knock on my door trying to buy it over the years. I may sell it this year if the money is right. Weighs a tonne but towes well, much better than it did as a van. I'd trow 2 tonne on mine as is. YMMV.I'm just a startled bunny in the headlights of life. L.J. Young.
We live in a free country. We have freedom of choice. You can choose to agree with me, or you can choose to be wrong. Me.
11th Jan 2013, 03:26 PM #3
Hi Krico, and Welcome.
The thing to be mindful of with using a Caravan chassis as a flat top tray trailer, is that most older caravans designed their chassis to have the walls of the caravan as part of their structural integrity. So once you remove the body, the chassis will be quite flexible, ie; not ideally suited for large loads either end of a long trailer without additional support. But it sounds like your chassis will be able to cope
Your axle placement calculation is correct. If you're mounting the tray and the box on the chassis and the box was is going to be permanent, then yes, incorporate the box in this measurement. If the box was to be consistantly removable, then I'd suggest not.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
11th Jan 2013, 07:46 PM #4New Member
- Oct 2005
- 0
Yonnee,
Thanks for the reply. I think with the size of the current rails and welding in cross members the same size or maybe 100 x 50, it should be a fairly rigid frame. Length wise it should be ok. I think I am going to have to lift the tray to get tyre clearance anyway so I may be able to incorporate a web like frame under the tray rails to stiffen it up length wise.
I am picking the tray up on the weekend but do you think welding in cross members will be enough for tray support or should i pack it further out on top of the chassis rails.
And is 70mm enough clearance for tyres with roller rocker suspension under the tray?
Krico
14th Jan 2013, 05:02 PM #5New Member
- Oct 2005
- 0
Well I picked the tray up on the weekend. Not a bad deal for the $260 I paid for it.
tray1.jpgLast edited by krico; 14th Jan 2013 at 05:03 PM. Reason: Add photo
23rd Jan 2013, 03:08 PM #6Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
Alloy truck tray for trailer
By Wallie in forum TRAILERS & OTHER FABRICATED STUFFReplies: 6Last Post: 16th Oct 2012, 07:45 AM -
Another Tray Trailer
By GU2001 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 31Last Post: 21st Feb 2011, 08:49 AM -
2 Kart / caravan trailer progress
By Tim37 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 18Last Post: 12th Nov 2010, 09:55 PM -
Building a Trailer from Damaged caravan
By StrathfieldMens in forum TRAILERS & OTHER FABRICATED STUFFReplies: 11Last Post: 12th Jan 2010, 09:17 AM -
Using a ute tray for a trailer
By spooled in forum TRAILERS & OTHER FABRICATED STUFFReplies: 12Last Post: 26th Apr 2009, 11:32 PM
