Results 1 to 5 of 5
31st Aug 2012, 08:36 PM #1Member
- Dec 2010
- queensland
Tilt trailer drawbar latch - wot is best design
I am currently tossing up what type of catch to put on the drawbar of my 3.5T tilt car trailer currently under construction. Does anyone have any good ideas on a convenient latch that I can use to lock the drawbar into place ?
John
1st Sep 2012, 02:24 PM #2Novice
- Oct 2004
- Regional South Australia
- 24
Mine uses a spring loaded barrel bolt welded to the chassis that slots into a piece of angle iron that is welded to the subframe..
1st Sep 2012, 02:58 PM #3
Jex,
I have just come in from helping a mate start a tilt trailer project. He is a mechanic and had one to retrieve dead vehicles, evan caravans, to work on them. His "Mark I" was about 25 years old and he only sold it 2 weeks ago to fund this new project. I will include a couple of photos to show you how he latched down the "Mark I". He used 2 Slam Catches, used on cattle yards. They are made from 20mm round bar with springs to latch them. They are very robust and worked well.
I could get a close up of the Slam Catch if you like. I would have to actually take a separate shot of one I have here at home.Just do it!
Kind regards Rod
2nd Sep 2012, 10:24 PM #4Member
- Nov 2011
- sunny adelaide
- 63
i just esed 2 big bolts one on each side that screw into a nut welded under a thick bit of flat steel will takes some pics for you .
im not keen on catches as some of them rattle about at least with bolts the tray is bolted down tight to the draw bar .
2nd Sep 2012, 10:44 PM #5Member
- Aug 2002
- Boyne Island, Queensland
- 51
- 68
I did the same as Mid Life. Brackets and bolts where the chassis crosses the draw bar.
Dan
tilt car trailer build
By mid life crisis in forum TRAILERS & OTHER FABRICATED STUFFReplies: 52Last Post: 25th Jun 2015, 09:05 PM -
Telescopic extension to Trailer drawbar
By John H in forum TRAILERS & OTHER FABRICATED STUFFReplies: 15Last Post: 11th Nov 2012, 08:14 PM -
Tilt Trailer
By SurfinNev in forum TRAILERS & OTHER FABRICATED STUFFReplies: 2Last Post: 25th Mar 2012, 11:35 PM -
Tilt car trailer plans required
By jex in forum TRAILERS & OTHER FABRICATED STUFFReplies: 6Last Post: 18th Dec 2010, 08:21 PM
