Results 16 to 29 of 29
Thread: draw bar/chassis wall thickness
15th Jun 2012, 11:18 AM #16Novice
- Sep 2008
- Mount Richon
- 16
a couple more photos
15th Jun 2012, 12:43 PM #17Diamond Member
- Jun 2010
- Canberra
- 1,322
That's a very nice looking setup. Is that a B7100?
15th Jun 2012, 12:53 PM #18Novice
- Sep 2008
- Mount Richon
- 16
Yes, RustyArc, that is my trusty old B7100. Small machine that punches well above its weight, super handy for our yard.
16th Jun 2012, 10:16 AM #19
Nice work.
If you haven't already, don't go to the expense of tandem guards (like in the pic in the first post). All you require is a pair of single guards cut accross the middle. Weld each half onto the tray at either end of the wheels and tyres.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
22nd Jun 2012, 03:44 PM #20Member
- Jun 2009
- Toowoomba QLD
Looks good.
Where have the hydraulics come from, and what sort of $$ damage are they?
22nd Jun 2012, 04:02 PM #21Novice
- Sep 2008
- Mount Richon
- 16
The hydraulics were purchased second hand of a Toyota Dyna, not something that comes up all that often. For the pump /ram/hose it was $800. Oh that also included the rear hinges
20th Jul 2012, 03:21 PM #22Novice
- Sep 2008
- Mount Richon
- 16
Just a quick update seeing as this site has become so quiet
At the moment just trying to finish the last few things before the trailer gets blasted and painted.
mudguards. Used the original mudguards that came with the tray, just had to cut them down and bend one side. Mudflaps still to be attached to the bottom of the rear guards.
Added a toolbox to house the pump/battery. Replaced the hydraulic hose with a longer one to suit the new location
remodeled the back to include a protection recess for the lights
Hopefully not much longer to go now, as im keen to get it on the road and try its first load.
5th Nov 2012, 10:14 PM #23
That trailer looks great.
What is the total weight?
And what is the load limit?
Do you have some final pics?
And an estimate of costs?
Pulpo
7th Nov 2012, 06:57 PM #24Novice
- Sep 2008
- Mount Richon
- 16
hi Pulpo,
Unfortunately the trailer is not finished yet, pretty much at the same stage as what appears in the pictures due to other more urgent projects. Will finish it of the coming summer i hope.
I estimate the trailer to weigh around the 1 tonne mark, with load limit of 2 tonnes (3t total)
Cost to date is around 4500 including tray/hydraulics/suspension, a bit more to go with paint and licensing.
regards
Harmful81
8th Mar 2013, 11:36 AM #25Novice
- Sep 2008
- Mount Richon
- 16
some update pictures. The trailer is completed and licensed and in use.
8th Mar 2013, 12:03 PM #26Member
- Jun 2009
- Toowoomba QLD
Looks great.
What did the weight of it come in at?
8th Mar 2013, 12:33 PM #27Novice
- Sep 2008
- Mount Richon
- 16
surfin,
The weight came in @ 1060kg. I originally estimated it @ 1 tonne, so i am pleased with the outcome. It leaves just shy of 2 tonnes of payload which equates to a decent amount of sand.
One of the first runs was for some lawn sand, and it quite comfortably handled 6 scoops (wheres my previous trailer was max 3 scoops) the hydraulics handled tipping that weight no dramas as well so overall quite stoked at the outcome.
harmful81
9th Apr 2013, 05:01 PM #28New Member
- Apr 2013
- brisbane
- 2
thats a great trailer mate.
Mate,
I am in the process of building one myself. What was the thickness of the stell plate for the pivot ?
Thanks again for sharing this with us.
dan
13th Apr 2013, 09:08 PM #29
im very impressed have been contemplating this for a while yet have not been able to find good plans. did you have a plan or make one yourself or did you just feel your way through it?
in info would be a great help
Cheers Rob
Wall thickness on A frame draw bars
By Grahame Collins in forum TRAILERS & OTHER FABRICATED STUFFReplies: 11Last Post: 5th Apr 2010, 05:37 PM
