Results 1 to 4 of 4
1st May 2012, 02:01 PM #1
Tipping Trailer Pivot Pin & Bush Supplier Req'd
Hi,
Do any of you guys know where l can source a tipping trailer pivot pin assembly kit from?
I'm looking for the body subframe to chassis connection and it should be suitable for a 2000kg load (Even though the trailer GTM will be 2000kg it will be overloaded with wood etc on the farm l'm sure.
5th May 2012, 09:14 PM #2Member
- Dec 2010
- nsw
- 51
I'd use a inch round bar with heavy inch pipe.
7th May 2012, 08:19 PM #3Most Valued Member
- Sep 2010
- Lebrina
- 1,910
I wouldn't. Pipe will be too light in the wall plus will have quite a pronounced seam internally..
Any machine shop will turn you a couple of bosses fron some hollow bar for minimal cost. Add some 1" BMS round bar and you are away. Get them to add a couple of grease nipples and it will be even better. Make sure that you tell them that you will be welding the bosses so they machine them a little oversize to allow for shrinkage.
You could also talk to the supplier of your hydraulic ram as they will typically have access to such items.
9th May 2012, 12:37 AM #4
The earthmoving industry has quite a range of pins & bushes for various applications, some are even greasable.
Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
Flat Top Trailer for the Bush
By rod1949 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 18Last Post: 12th Jun 2012, 04:14 PM
