Results 1 to 6 of 6
24th Mar 2012, 07:36 PM #1Member
- Apr 2011
- Brisbane
- 91
Thickness of steel required for ute tray cage
Hi guys,
did a brief search and didn't turn up much so i'll make a thread.
I've recently purchased an '06 alloy tray falcon, and the fitting out is set to commence
It currently has mounting plates for a rear ladder rack and it has an inbuilt front rack that's build into the tray (triple M tray)
I plan on putting some mounting plates up the front of the tray, as far forward as it'll go, and making a 3 walled cage. more specifically, i plan on using the ladder rack mounts to bolt 2 inverted U shaped frames along each side, and attaching a hinged rear gate to close up the cage.
couple of questions for those with experience;
for the mounting hardware up front, i plan on using some 3mm galvanised builders brackets- bolting directly to the tray and also to the headboard of the tray at the front. i plan on putting plates either side of both bolts. some square tube will be welded to these brackets, with a hole and a nut welded on so the cage components can slot into the tube and get bolted in place. sound alright?
secondly, what would you suggest as the minimum thickness of the actual cage tubing (square tube)? I wish to make it out of 304 stainless, i know its a bit more expensive but i love the stuff, lol. any structural reasons not to?
thanks in advance and let me know if i've been confusing in my description
25th Mar 2012, 05:11 PM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
If it were me, I'd be using Galv SHS or RHS not Stainless (WAY!!! cheaper, and easier to source). 25x25x1.6 will be plenty strong enough for that application, or if you can weld thin tube 38x20x1.2 Galv RHS (common fence rail size) would do the job too.
26th Mar 2012, 07:20 PM #3Member
- Apr 2011
- Brisbane
- 91
thanks mate- given the size of the mounting hardware already in place, i'll be using 38x38x1.6 304 tubing for the job.
being that i use alot of stainless tube i have a fair few odd lengths around, so i'd happily use that for the cage instead of buying the full amount required in gal tube
cheers
corgan
27th Mar 2012, 05:52 PM #4
No structural reason not to use Stainless. Just be aware of attaching the cage sides to the frame. I've seen many a nice bow in the length of a tube after the mesh has been welded in from one end to the other...
Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
27th Mar 2012, 07:56 PM #5Member
- Apr 2011
- Brisbane
- 91
Fair call yonnee- I'm well used to dealing with distortion. Tig and slowly, I should be fine. Hopefully get most of the work done this week, I'll post it up
27th Mar 2012, 08:56 PM #6Most Valued Member
- Sep 2010
- Lebrina
- 1,910
With the number of welds required to hold the mesh it will still distort no matter how you weld it, tig, mig or otherwise.
I do like the idea of SS for the frame though, it will maintain it's appearance beautifully over the years.
I would use SS plates to mount rather than the galv builders brackets though.
Cage for Trailer
By lnt9000 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 14Last Post: 14th Nov 2012, 09:49 AM -
Its the all new, all steel, truck tray......
By ozwinner in forum METALWORK GENERALReplies: 11Last Post: 13th Sep 2006, 05:22 PM
