Results 1 to 15 of 16
Thread: Flat top car trailer
23rd Mar 2012, 07:34 PM #1Member
- Dec 2010
- queensland
Does anyone know where I can buy plans for this USA flat top car trailer ? I have checked most Aussie sites and none seem to have a clean flat top like this one
23rd Mar 2012, 08:23 PM #2Intermediate Member
- Apr 2010
- Warwick QLD
- 53
- 26
If by "clean flat top" you mean "without the side & front barriers" keep in mind that local laws & regulations are different to those in the US.
A bit more info as to what you want would be useful.
23rd Mar 2012, 08:25 PM #3
24th Mar 2012, 08:33 AM #4
Two reasons we don't see many like that here in Australia is firstly the size of material required for the main chassis rail, and secondly, there's not much point. The main reason for eliminating the side rails is to allow the doors to open on a really low race car, but with the guards sitting up as high as they do, they are what's going to be in the way.
The Master Plans & Designs kit shown requires a 5" channel for the main chassis... that 125mm! They need this sized material as there's no other support for the chassis. You can build a trailer with a deck 50mm lower to the ground by simply using 75 x 50 x 3mm RHS and then trussing it with smaller SHS up to the top of the guards.
Whichever way you decide to go Jex, just make sure you document the build on here.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
24th Mar 2012, 08:55 AM #5Retro Phrenologist
- Oct 2009
- Springfield NSW
- 70
- 75
____________________________________________________________
there are only 10 types of people in the world. Those that understand binary arithmetic and those that don't.
24th Mar 2012, 10:11 AM #6Member
- Dec 2010
- queensland
Thanks for your replies.
I did not realise it would require 125mm side rails. I thought they would have been around 100mm.
My previous car trailer had trussed sides and they were a pain in neck during entry/exit to a vehicle, especially a low vehicle. I agree, the mudguards are also a problem but with a higher trailer this would not be as pronounced.
I have 2 x 12" electric brake axles & wheels rated at 4 tonne so a 3t load rated trailer to cover 4wd would be preferable. The car trailer plans on the web seem to be all 2.5T rated. A general purpose flat top would probably do the job as well. It could be used for vehicles or converted to a covered trailer if required
John
24th Mar 2012, 01:23 PM #7Senior Member
- Dec 2011
- South East Queensland, Australia
- 355
Here's a link to an interesting trailer USA. Something similar with the fold down mudguard might be a thought.
Good tilt trailers make life easy, though the crook ones, and a couple of which I've been involved with, are a right PIA.
The ones with high side rails are a real pain, I'm a bit less flexible than younger days to slide up out the window
Tilt Trailer Plans For Towing Business
Good luck with finding or working out a design that you like
Cheers.
If I'm not right, then I'm wrong, I'll just go bend some more bananas.
24th Mar 2012, 01:44 PM #8
The thing about designing/building a car carrying trailer is getting the guard height you want. The wheel and tyre diameter of the trailer isn't going to change. You need suspension clearance from the trailer's tyres to the under side of the guards. So that can't change either. What you can then change, is the guard height to floor of trailer measurement. But this comes with a centre of gravity/floor height trade-off. You can have the floor level with the guards as a flat top trailer, but your floor height will be around 700mm. Drop the floor to between the guards, using straight axles, Slipper Springs, and a 75 x 50mm chassis rail (assuming a 600mm tyre diameter), your floor height will drop to around 500mm, and floor to guard height can be around 175mm. Using 4" drop axles, you floor height can drop to 400mm, but your floor to guard height increases to 275mm.
24th Mar 2012, 08:41 PM #9Member
- Dec 2010
- queensland
Yonnee, what wall thickness would you use for a 3T frame using 75mm rails? Would the draw bar be the same size & wall thickness?
John
25th Mar 2012, 08:14 PM #10Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
What are you planning to pull it with?
A 3000Kg payload + mass of trailer (around 600-800kg wouldnt be unrealistic) will put it beyond the legal towing of pretty much every passenger car (4WD's included).
25th Mar 2012, 09:11 PM #11Senior Member
- Dec 2011
- 355
25th Mar 2012, 10:21 PM #12Most Valued Member
- Mar 2011
- 1,552
The issue is not the point loading on the ball. The ball should have around 5-8% of GTM sitting on it. At 3000Kg that number should be closer to 5%. Most towbars are rated for 5-8% plus a safety margin. 5% of 3000kg is 150kg, thats only one and a bit people standing on the ball. A properly set up car with sufficient towing capacity shouldnt even notice that sort of point load on the ball.
The main issue is Aggregate Trailer Mass. The new Mazda 4x4's are being advertised with a tow of 3500kg. Very unlikely you can make a trailer with a 3000kg payload that weighs 500kg or less to fit within the 3500kg tow of say a Mazda. Just the shear weight of the axles, wheels and springs are against you when you start wanting to pull those sort of weights.
Pulling those sort of weights does wonders for your fuel economy too..
25th Mar 2012, 10:48 PM #13
I'm going to assume John means a 3000Kg ATM as opposed to a 3000Kg payload.
Originally Posted by racingtadpole
And a 20Kg towball weight for an unladen 6x4, for me is a little light.
However, I would only rate the trailer at 3500Kg, as this the highest capacity you'll get in a 50mm towball and any 50mm coupling. This is also the cutoff point for the next level of safety chain required.Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
25th Mar 2012, 11:21 PM #14Too many projects, so little time, even less money!Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds! Doing work around the home? Wander over to our sister site, Renovate Forum, for all your renovation queries.
26th Mar 2012, 10:39 AM #15Member
- Dec 2010
- queensland
Yes, 3000kg atm. I am towing with an Iveco 50c18 truck that I currently use to tow a 5T 5th wheel RV. 5th wheel or gooseneck trailer would be nice but that would be narrowing down the tow vehicle type. I thought the rails & drawbar would be 4mm, would that be over engineering ?
Flat Top Trailer for the Bush
By rod1949 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 18Last Post: 12th Jun 2012, 04:14 PM -
help me build a basic flat build bed trailer for my kayaks
By gros21 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 7Last Post: 13th Oct 2011, 08:47 AM
