Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Mar 2008
    5
    Thanks for the replies. Justin, I think you make a good point in that it's not for business so from that perspective it doesn't need to be solid as a rock and last 20years but of course it must be roadworthy.
  2. #17
    Apr 2010
    Warwick QLD
    53
    26
    I've seen a lot worse... oh, wait... I mean I HAVE a lot worse. Ok, I'm a panel beater by trade so cutting, welding, grinding, metal fabrication in general is what I do, but check out what I started with only three weeks ago...
    I'm almost done, but I can start a build log if anyones interested.
    As far as welding goes: it's not that hard once you get used to it. Arc has it's good & bad points & takes time to perfect. As for cheap MIG welders, well, I own one. It's not perfect & I've had a few problems but, in general, it's not that bad, even running gasless it get's the job done. Also, in my opinion, Mig is the easiest type of welding to master.
  3. #18
    Victoria
    11
    I am in the same boat as you Pooran
    For those out there with heaps of MIG experience what type of MIG welder do u recommend with a budget of around 500-600 dollars
    Omer
  4. #19
    jatt's Avatar
    jatt is offline Always within 10 paces from nearest stubby holder
    Bendigo
    51
    762
    I'm with Wimmera Jack.
    If it has a compliance plate thats still legible i would try and save that too.
    At least then u have saved part of the trailer.
    I would start making a few things around the house (gates etc..) first before attempting a trailer, especially if you are gunna to fix the old one. Its easier to get good welds on fresh and clean steel.
    U dont a trailer to fall to bits at 100 kays. I dont think your father would want that to happen.
    Just my 2 bobs worth.
    Frisky wife, happy life. ​Then I woke up. Oh well it was fun while it lasted.
    From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
  1. Tandem Box trailer questions
    By Dan in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 3rd Sep 2012, 12:19 AM
  2. car trailer questions?
    By matt9422 in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 21st Mar 2011, 08:34 PM
  3. Trailer questions?
    By WazOz in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 2nd Jul 2008, 11:44 AM
