Results 1 to 4 of 4
    Mar 2008
    nowra
    1,598
    Default Andre's homebuilt tractor
    hi guys Yonnee wanted to see pictures of my homebuilt tractor so here they are iam still working on her just need to finish welding the hydraulics tank then plumb the hydraulic and in stall the electrics then test run away.
    the machine is fully hydraulic it is articulated steering hydraulic drive and is powred by 27 hp onan engine. later on i will build a front loader and possibley a backhoe for it here are the pictures.
    the first pic is an overview of the tractor and the second is the articulation joint
    all the best andre
    Mar 2008
    nowra
    1,598
    here she is today first run is hoped for next week in it new paint colour jd green
    Mar 2008
    nowra
    1,598
    sorry here is a larger pic
    Jul 2008
    Sydney
    210
    Will you be driving the axles off one motor or two.
    Two sounds simpler as you don't need to bend and stetch the drive shafts.
    Looks cool.
    Much more fun building something than buying one built in a factory. And you can say "I did that".
  1. Andre's articulted tractor build
    By welder in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 29th May 2009, 04:47 PM
