Results 1 to 10 of 10
24th Jun 2009, 07:24 PM #12-legged animal
- Jan 2008
- Murwillumbah Nthn NSW
- 68
- 118
Preventing rust on welded zincalume or galvanized steel?
Painting the welds doesn't seem to last in the weather nearly as good as the zincalume on the metal surrounding the weld .Is there anything, like say zinc or tin or silver solder or something, that can be melted onto the weld which is as hard wearing and rust resistant as the gal or zincalume ?I did hear something about sticks of some sort of galvanizing that can be melted and wiped onto the hot steel.Anyone familiar with a product like that ?
thanks all ----mat
24th Jun 2009, 10:28 PM #2
I simply use cold gal in a pressure pack after hitting the weld with a wire buff. Seems to last reasonably well out in the weather.
Of course its not as good as hot dip gal etc... but its quick and easy for me.
Cant say I have tried the other things that u mentionedFrisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
24th Jun 2009, 10:43 PM #3China
- Dec 2005
- South Australia
- 1,656
I use a stick of zink can't renmember the name I bought a pack of 50 years ago and they will most likley see me out, you melt it on the hot weld and spead it with a wire brush, most welding supply shops have it
27th Jun 2009, 02:42 PM #4Senior Member
- May 2009
- SW Sydney
- 101
Cold gal works well, I find the stuff in the can is better than the spray on version. Killrust looks the bees knees when done right and works great outside but if something has to be painted you cant go past POR15.
27th Jun 2009, 02:44 PM #5
Cold gal
Ashore
The trouble with life is there's no background music.
27th Jun 2009, 04:58 PM #6Cold gal
__________________
Ashore
28th Jun 2009, 11:53 PM #7
Have alook at "GALMET" brand "DURGAL".... the stuff is magic.
most of the other "cold gal or zinc spray products just done come near it.
It is a thinners Bassed spray on product.
the thing about it is that it has far more resin in it than most of the other gal or zinc products and it sprays up and look real good...If you spray it nice it looks as good as wheel silver.
It is a full blown paint not just a zinc coating.
I did a job on the broinlsw's boat trailer over 5 years ago... and it is still standing up well.
It was originaly intended for patching welds in zincalume and gal steel.
A little goes a long way.
People are made of meat.
29th Jun 2009, 09:59 PM #8China
- Dec 2005
- South Australia
- 1,656
Have a look here http://bobthewelder.com.au/product.p...&cat=32&page=1
1st Jul 2009, 11:46 PM #9New Member
- Dec 2008
- 1
I use a stick called Galmend that is available from BOC.
While the weld is still hot,give it a quick brush, then rub the end of the stick on the weld. If it hasn't cooled off too much, the stick should melt and flow over the weld. Spread it around with the wire brush and Bob's your auntie's live -in -lover.
If it has cooled off warm it up with the oxy torch and continue as before.
2nd Jul 2009, 11:12 AM #102-legged animal
- Jan 2008
- 68
- 118
