Results 1 to 4 of 4
Thread: Just brazed up fuel tank-safely
26th May 2009, 08:03 PM #12-legged animal
- Jan 2008
- Murwillumbah Nthn NSW
- 69
- 118
Finally got around to brazing up the rust holes in the old landcruiser petrol tank.After all the controversy and warnings I did it really safely.
I completely submerged the tank in a big tub of water with only the bit I was braising just sticking out of the water .Worked well and didn.t even explode .How could it ? No air or oxygen --full of water submerged and surrounded by water
26th May 2009, 10:20 PM #2China
- Dec 2005
- South Australia
- 1,658
Good one !
31st May 2009, 11:17 PM #3Golden Member
- Jun 2005
- Helensburgh
- 618
I don't see any problem if done right. I saw CIG techs do a demo on this, empty the tank, flush with water and purge with an inert gas. I stood well back but it didn't blow up so they must have known what they were doing.
CHRIS
8th Jun 2009, 09:43 PM #4Senior Member
- Jul 2008
- 210
We did a simillar thing years ago at Birdsville with a split tank.
We filled it with loverly Birdsville grey water and hit it with the TIG (alloy tank) and it promptly went poof and split another seem.
Turns out it had a blocked fuel return line (the tank builder got carried away with Loctite) and the the tank held enough fumes to ignite.
You can never be too carefull.
The same tank split 3 days later so we used a ratchet tie down and epoxy and that lasted for another 4 days until we finished the Rally.
brazing fuel tank?
By Mathuranatha in forum WELDINGReplies: 36Last Post: 26th Apr 2009, 12:14 PM -
Motorbike fuel tank repairer
By Outsider in forum METALWORK GENERALReplies: 6Last Post: 19th May 2008, 10:49 AM
