Results 16 to 20 of 20
Thread: Welding pipe at angle onto RHS
27th Sep 2007, 04:41 PM #16Member
- Nov 2006
- Hobart, TAS
- 51
Thanks also to those who suggest the bashed flat method. Bashing steel is very therapeutic, and I think I myself recommended this very method on this forum for monkey bars! Will try it the hard way as practice is a good thing to have.
27th Sep 2007, 07:26 PM #17Member
- Nov 2006
- Hobart, TAS
- 51
Well I had a crack and it was easier than I thought. I've attached a photo of the first attempt for your amusement. Main problem was trying to constantly contort around at the appropriate angle. Dodgy weld I know, but it's good enough and with some judicious grinding and a generous coat of paint it should be pretty right.
Surprisingly I had no trouble underneath. I used 2.5mm Liquidarc "Easyflo Supa" rods which are for "the less experienced welder". I reckon they are mirical rods. The angle is around 30 degrees. Didn't even look like blowing through using Grahams method and the little Ozito welder handled it amirably.
27th Sep 2007, 09:26 PM #18China
- Dec 2005
- South Australia
- 1,657
Good one acton, you've obviously got the hang of it, you will only get better
27th Sep 2007, 09:46 PM #19Main problem was trying to constantly contort around at the appropriate angle.
For a first go I'd sat the weld is a great start!Have a nice day - Cheers
27th Sep 2007, 10:14 PM #20
Good one
Onya Acton
No holes
No slag
No worries
Its a big post for chooks. Are they the size of Emus?
Glad to see it worked out for you.
Welding 1 -The good, the bad and the dangerous
By Grahame Collins in forum WELDINGReplies: 1Last Post: 20th Jun 2007, 12:05 PM -
Welding Water Pipe
By Riverland in forum METALWORK GENERALReplies: 7Last Post: 8th Aug 2006, 01:25 PM -
More on MIG selection
By Grahame Collins in forum WELDINGReplies: 12Last Post: 1st Apr 2006, 04:38 PM
