Results 1 to 13 of 13
Thread: MIG pulse welders
5th Mar 2006, 11:05 AM #1Intermediate Member
- Mar 2006
- Waikerie SA
- 39
MIG pulse welders
Hi, first post, this looks like a great forum, hope to spend some time here.
Can you buy cheap (Chinese etc)single phase pulse mig welders
5th Mar 2006, 03:51 PM #2Originally Posted by vin
PROBABLY
Can you buy the cheap replacement circuit board once the above cacks itself due to power surges and the like ?
NOPE!
Whatever you buy will not be CHEAP unless spares are availabe.Work on whole of life cost comparisons.
Why do you need a pulsed mig for ? A few more details on what you would hope to do would enable people here to give you a defined answer. Your experience to date with MIG would be handy too
5th Mar 2006, 04:24 PM #3Intermediate Member
- Mar 2006
- Waikerie SA
- 39
Pulse mig
Grahame, I am thinking of doing something a little challenging, I am thinking about building an aluminium boat probably about 5.5mt first. then maybe something bigger later. I have never welded seriously aluminium, over the last few weeks i have set up my CIG 220 with a teflon liner and suitable roller and have been playing around. I thought if i could get a pulse mig for $2500-$3000 single phase i would be tempted to buy one. Below are some links of mine, the first one is just my website and the second one is my last project. Please give me your thoughts?
http://stonevahestate.tripod.com/
http://stonevahestate.tripod.com/houseboat/
5th Mar 2006, 04:51 PM #4
Vin
That info makes it real easy to give answer.
If anybody needs a pulsed mig for a particular project it is you.Bearing in mind what I said about parts availability,I would say WIA (Welding Industries of Australia) might be the go.These blokes developed the pulsed MIG in conjunction with CSRIO.
Remember the Australia ! BONDYs Americas Cup racing yacht.It was welded up using the then newly developed WIA pulsed Migs.If there are single phased pulse migs around WIA will be the first port of call.They are good quality welders.The apprentices at TAFE 20 years ago could not kill them.
By now you will have found out what a pain in the bum that using a push gun-which is the standard gun with the drive rolls in the welder body that PUSH the soft aluminium wire forward. What works really well if you can afford it is the PULL type gun.The drive rollers are built into the head behind the contact tip are. It will drag the wire through. Costly yes! but consider you could sell the unit when you finish you project.
If you can't go to a PULL torch .- Keep your existing torch cable as straight as possible to minimise drag (slows down your wire feed rate and amps plus promotes wire tangle at the drive rolls. )
Google up WIA they have a website But from memory you will need Adobe for the PDF format.
Cheers Grahame
5th Mar 2006, 06:05 PM #5
240v pulseMIG
Vin
I took my own advice and looked for a 240v pulsed mig.There does not appear to be a model available in any brand.My apologies
30th Mar 2006, 09:37 PM #6Senior Member
- 316
Hi Vin,
Without trying to embarress you I was very impressed by your little project. May I be cheeky enough to ask how much it would have roughly cost to build?.
David
23rd Dec 2007, 01:25 PM #7New Member
- Dec 2007
- 6
Fronius make a pulsed single phase mig welder.
23rd Dec 2007, 02:04 PM #8
4th Aug 2008, 06:00 PM #9Novice
- Jul 2008
- cairns
- 18
where can the info on this fronius 240v pulse welder be found?
sean
1st Oct 2008, 08:05 PM #10New Member
- tamworth
- 2
10th Oct 2008, 10:31 PM #11Novice
- Jul 2008
- cairns
- 18
really appreciate that information, i am looking at building a 45ft ally sailing cat and would prefer not to go down the 3 ph if i could help but i would like to have the pretty pulse look of the welds, i can weld ally pretty well with a normal mig but hey i figure if im goping to do this i may as well buy a decent welder, im only lookingat welding 4mm so really not looking for high power, ill have to have look at these welders and see if anyone has one in the area
sean
16th Oct 2008, 11:49 AM #12www.phasechanger.com
- Sep 2008
- Longwarry, Victoria
- 9
MAte,
If you need three phase you have a wide range of options. You can connect to utility (often quite expensive, but if you get ti cheap enough DO IT!). You can also choose to purchase a single to three phase power converter. We sell these and VSD's (which can onyl run one motor at a time, and at 240V rather than 415V). A power converter will allow you to run 3 Phase 415V from your existing single phase supply and can run any welder on the market. The following sizes will give a rough idea as to what unit you would be looking at for a welder of a certain size.
0-180A (PC 4kW)
180-250A (PC 6kW)
250-350A (Pc 8kW)
350-440A (PC 11kW)
An 8kW converter, which is out most popular model is sold at retail for 3800+GST. It can also be used for any number of machines up to the power rating on the unit. So you could use a number of machines at the same time, as long as when added together they do not exceed the 8kW rating of the converter. This is a unique feature to a power converter over a VSD (which can only run one machine at a time @ 240V output).
If you have any questions, please feel free to contact me betwen 8am and 5pm from Monday to Friday. I would enjoy answering your questions, and giving you possibilities of how to gain three phase for a minimum of costs.
Kind Regards,
Tom Fraser
Phase Change Power Converters
10-12 Mackey Street
Longwarry, Victoria, 3816
(03) 5629 9799
[email protected]
22nd Dec 2008, 10:35 PM #13New Member
- Dec 2008
- mascot
- 1
Hey guys apologies for coming on here just for this but I am selling a brand new Cebora 2035M Pulse mig welder,it was only used once when I attended a tradeshow in Tassie otherwise it is brand spanking.
Looking at $3K firm.
Standard 1 year warranty will apply. We are selling due to moving to a smaller office and only keeping our main lines of products for the freight company to pack and send for us.
Please feel free to contact me on 0400 185 679,item is located in our factory in Botany and inspections are welcome. Please no lowballers the RRP is much more than the asking price.
Sorry mods if this is against the rules,please remove the post if need be.
Nathan
Advice on Gasless MIG welders
By Bodgy in forum WELDINGReplies: 19Last Post: 14th Jan 2007, 11:24 AM -
More on MIG selection
By Grahame Collins in forum WELDINGReplies: 12Last Post: 1st Apr 2006, 04:38 PM -
MIG for beginer
By Gaza in forum WELDINGReplies: 9Last Post: 19th Feb 2006, 07:11 PM -
Welders - Difference Between?
By HappyHammer in forum WELDINGReplies: 21Last Post: 11th Mar 2005, 09:41 AM -
Using TIG power source for MIG welding
By HappyHammer in forum WELDINGReplies: 2Last Post: 7th Jan 2005, 11:52 PM
