Results 1 to 5 of 5
20th Mar 2023, 04:58 PM #1
Mystery Silver Brazing Rod? Stamped "5P"
Hi there
I have been cleaning up and sorting brazing stuff.
I found an interesting smallish section of what appears to be Silver Brazing rod, 0.118 inch dia and stamped "5P".
When scraped with a knife, it looks very slightly more yellowish than CIG SBA245, but much less than say Tobin Bronze, melts slightly higher than SBA245, and a little less to "wick" than SBA245, and has no tip colour.
As it came from an old workshop, it may be up to 70 years old.
I am just curious.
I know that this is incredibly difficult, but does anyone recognise it please?
20th Mar 2023, 06:09 PM #2Most Valued Member
- 2,672
I have no idea personally, but did find this when searching online
https://www.mkt.ee/en/silver-brazing...en-cp-104.html
26th Mar 2023, 03:23 PM #3
Thanks Steve.
Probably a lower silver content type rod for plumbing etc.
I see that CIG now stock only a flux coated 45% rod, and even that is possibly "obsolete", and, ... that a search on CIG website for SBA245 returns no product.
Lucky for me that 45% rod is still widely available in other brands and outlets.
26th Mar 2023, 04:15 PM #4Senior Member
- Apr 2021
- 212
SBA245 contains cadmium - that is probably why it is no longer listed.
I don't know what 5P is but 5% Ag and containing P (Phosphorus) is a possibility.
I'm not sure if it is still used but alloys containing phosphorus were used for brazing (not braze welding) copper/brass tight fitting socket type joints in plumbing etc.
Jack
29th Mar 2023, 05:05 PM #5
My money is on a 5% silver content rod.
Let's face it, if you are buying engineering supplies that are up to 70 years old, you probably wont be using it on anything of importance where you'd need to be assured of the metallurgical properties of the rod and weld deposit.
If you were feeling scientific, a 45% silver rod has a solid to liquid state between 640-680 celsius. Compare that to a 5% rod which has a range between 654-810.
A rudimentary testing method might be:
Provide heat to a heatsink of some capacity (metal block), measure temp at top surface as heat is applied from below. If a small sample of your mystery rod melts at a higher temp, chances are its a lower silver content that a 45% rod you are familiar with. Compare similar diameters of course.
...Or just use the rod and leave it as one of life's little mysteries.
Russian Miniature Round-bed Lathe "Universal 3-inch" and "Delphin"
By pritchb in forum METALWORK GENERALReplies: 1Last Post: 24th Jun 2022, 04:43 PM -
A friendly "GUTEN TAG" from Austria (you know, the one lacking the "L")
By nanno in forum G'day mate - THE WELCOME WAGON -Introduce yourselfReplies: 6Last Post: 2nd Jul 2021, 05:33 PM -
Cleaning brazing "burns" from brass?
By onewing in forum METALWORK GENERALReplies: 2Last Post: 6th May 2010, 10:12 AM -
Opposing toothed "Clutch-Plate" Nuts? (a bit like "Castle" Nuts...)
By Batpig in forum METALWORK GENERALReplies: 6Last Post: 5th May 2009, 08:18 PM -
Difference "Galvanised" and "Primed" Steel
By Fr_303 in forum METALWORK GENERALReplies: 4Last Post: 22nd Jan 2008, 05:59 PM
