Results 16 to 29 of 29
22nd Nov 2022, 09:16 PM #16Most Valued Member
- Sep 2010
- Lebrina
- 1,910
You are dead on the money. People have forgotten that an awful lot of TIG welding was done with the good old DC generator welders in years gone by. The UNIMIG Viper will definitely TIG weld, but will lack Lift Arc capability (far from the end of the world in my humble opinion). The slightly greater chance of tungsten inclusions using a scratch arc compared to a lift arc machine will not bother 99% of TIG users.
If money was no issue, then I would always go for a HF start AC DC machine and a new user will find HF start easier to learn with, but there's nothing wrong with a basic scratch start machine for budget/infrequent use.
23rd Nov 2022, 10:43 PM #17
Just in case: you can do very nice brazing with a TIG torch! You just have to use right bronze rod... Have a look on YouTube for examples.
Cheers, Joe
24th Nov 2022, 11:32 AM #18Senior Member
- Apr 2021
- 205
Can you braze with TIG or only braze (bronze) weld?
I have done both with O/A but not with TIG. I would have thought that the heat from TIG would be too localised for brazing.
I assume by "braze" you mean braze weld but I am curious about the possibility of actual TIG brazing.
Jack
24th Nov 2022, 07:02 PM #19
RE: TIG - Yes you can. Silicone bronze. Aluminium bronze, to name a few.
Hard to explain, but you don't form a puddle, you just dab the rod into the arc and heat zone, and it wicks to the heat.
Remember, while not ideal, arc length (tungsten to work) can affect heat focus...
24th Nov 2022, 08:38 PM #20Senior Member
- Apr 2021
- 205
25th Nov 2022, 05:58 AM #21
You can also MIG braze, but let's not get carried away with that, for now.
FWIW the American Welding Society (AWS) has a basic definition of Brazing and Soldering:
Brazing and soldering share a number of features.
Both are liquid-solid state processes as they
involve molten filler metal and solid base metal, which
do not melt or mix. In both brazing and soldering, metallurgical
bonds are produced by mutual diffusion
rather than by fusion. Predominantly, the molten filler
alloy diffuses into the base metal. Some base metal is
also dissolved, diffusing into the filler metal. Although
the fundamentals of bonding are the same for both
processes, the temperature required to effect joining
determines whether the diffusion process is considered
brazing or soldering. Brazing takes place when the
metal is heated to above 840°F (450°C), while soldering
occurs below this temperature.
25th Nov 2022, 02:44 PM #22Senior Member
- Apr 2021
- 205
Thanks but I'm more interested in the difference between brazing and braze welding with respect to TIG. According to AWS A3.0:
braze, n.
A bond produced as a result of heating an assembly to the brazing temperature using a brazing filler metal distributed and retained between the
closely fitted faying surfaces of the joint by capillary action.
braze welding (BW).
A joining process in which the brazing filler metal is deposited in the joint without capillary action or melting of the base material.
So far, all of the "TIG brazing" I have seen others do and on YouTube has been braze welding. I would take some convincing that "MIG brazing" is anything other than braze welding. The difference is subtle and comes down to the joint type and design, and the way heat and filler are applied.
You are right though, no need to get carried away - I am just curious.
Jack
25th Nov 2022, 02:57 PM #23China
- Dec 2005
- South Australia
- 1,656
Is not Brazing and Braze Welding just two different names for the same thing?
25th Nov 2022, 03:10 PM #24Senior Member
- Apr 2021
- 205
26th Nov 2022, 03:44 AM #25China
- Dec 2005
- South Australia
- 1,656
Interesting when I did a welding course at Panorama TAFE ( long gone ) in the 80's using capillary action was soldering and was not done with bronze all brazing was achieved without capillary action
26th Nov 2022, 01:11 PM #26Senior Member
- Apr 2021
- 205
I think that most people who braze are actually braze welding and that is likely appropriate for the joints they are making. It only gets confusing when curiosity prompts me to ask a question about (real) brazing and everyone thinks I mean braze welding.
I have still not tried it myself, but I think TIG (and MIG) brazing are not realistic options. TIG and MIG braze welding are a different matter.
Jack
26th Nov 2022, 01:32 PM #27Senior Member
- Apr 2021
- 205
Your comment about training prompted me to check the training notes from the School of Mechanical Technology. They cover both brazing and braze welding.
Typical joints for brazing are all compatible with capillary action whereas braze welding joints are like typical welded joint preparations.
Jack
26th Nov 2022, 03:39 PM #28
While I've usually used the terms interchangeably- AWS does indeed differentiate between 'brazing' and 'braze welding'.
AWS Literature confirms that 'Braze welding' uses joint design not intentionally designed for capillary action. Filler material would be face-fed at the point where the brazement is needed, as opposed to 'brazing' which would use capillary action as the action through which the filler material is deposited into the joint. It's a fine line, and I'd wager many would call both processes 'brazing', but AWS does indeed differentiate.
For anyone looking for the definitive guide- AWS Welding handbook, volume 2, chapter 12 dedicates over 50 pages to the brazing / braze welding process. On top of that, later volumes discuss at length, the brazing considerations for specific materials.
27th Nov 2022, 11:47 PM #29China
- Dec 2005
- South Australia
- 1,656
Interesting
Budget welder for occasional aluminium welding..
By silkwood in forum WELDINGReplies: 12Last Post: 22nd Feb 2019, 05:54 PM -
Larger disposable cylinders
By Gringo in forum WELDINGReplies: 10Last Post: 1st Jan 2013, 08:37 AM -
Disposable gas cylinder thread
By wannabe in forum WELDINGReplies: 6Last Post: 11th Jun 2012, 09:12 PM -
Viewer Scope ..gimmick or not ?
By morrisman in forum METALWORK GENERALReplies: 3Last Post: 29th Jan 2012, 10:02 PM -
MIG disposable gas bottle connection
By Mick. in forum WELDINGReplies: 6Last Post: 3rd Jan 2012, 12:17 PM
