Results 1 to 4 of 4
26th Sep 2022, 05:42 AM #1
My welding skills are ... inferior
I am not a welder.
Against all odds I try to get a nice bead on thin material with an old stick welding machine.
What could possibly go wrong?
I present my questionable skills in this video
26th Sep 2022, 03:07 PM #2China
- Dec 2005
- South Australia
- 1,656
Need to turn you amps down, plus your electrode angle is incorrect, that type of join is not the best to start out on, you just need more practice, find some scrap and get your basic technique right doing simple butt welds.
26th Sep 2022, 03:10 PM #3Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Arc welding
Hello Finno.
If your using an old transformer welder ( heavy ) that could be part of the problem. They are AC and low open circuit voltage. Modern electrodes are formulated for DC and high voltage. A good web site to visit is weld.com A Canadian welding school with video thru the lens.
Another tip is clean the metal and don't try to weld air gaps.
BC
28th Sep 2022, 11:19 AM #4Senior Member
- Apr 2018
- 168
To get practice of laying down a nice bead, dont try to weld 2 pieces together.
Start by practicing on a thick piece of clean steel and get your beads looking right. play around with current and angles and speed until the weld looks ok then try joining metal together.
A butt joint is hard to do without blowing holes in it, start with lap joints .
Some welding and fab skills to aspire to
By Grahame Collins in forum WELDINGReplies: 3Last Post: 11th Feb 2022, 08:05 PM -
Gunsmithing skills on display 1969
By morrisman in forum GUNSMITHINGReplies: 8Last Post: 22nd Jan 2022, 10:44 PM -
What skills and tools do i need to build this?
By stonedpirate in forum METALWORK GENERALReplies: 27Last Post: 16th Apr 2015, 08:49 AM -
Having Welding Skills Assessed?
By ARock in forum WELDINGReplies: 1Last Post: 23rd Apr 2009, 07:24 PM
