Results 1 to 5 of 5
Thread: Welding Malleable Iron to steel
20th Jun 2022, 10:59 AM #1
I'm modifying a BSA centrestand, made from Malleable Iron, to HT Steel which is a lever which you stand on to help get the bike up on the stand. and I'm advised that arc will will do the job (I have a small inverter arc welder). OR: Brazing maybe? -I have only MAPP gas which is good for smaller stuff but I'd be dubious about getting enough heat into the mass of iron. Any advice? If I arc weld it would 2mm electrode be sufficient? ;img src="https://metalworkforums.com/attachment.php?attachmentid=398998&amp;stc=1" attachmentid="398998" alt="" id="vbattach_398998" class="previewthumb"><br><br>
20th Jun 2022, 06:41 PM #2
I'd use a 3.15mm electrode and 100-120A but do short welds all around. Steel to malleable iron welds OK. Grind the surfaces for the welds bright, so you get not surprises.
Cheers, Joe
20th Jun 2022, 06:54 PM #3
Ta Joe
I'll try that. Thanks Joe (BTW if anyone you know is after CX bits, I have some free to a good home, just new head gaskets, o-rings, m/c).
20th Jun 2022, 07:02 PM #4
I have no need myself, but there are always people asking for odd bits on the CX forum: https://australiancx.asn.au/forum/in...p?action=forum
Cheers, Joe
22nd Jun 2022, 09:53 AM #5
Success
Joe's recommendations, 3.2mm rod and 120A worked a treat. Successful weld.
(Very much easier arc welding this than thinwall steel tubing!)
Repairing malleable iron
By kenny_10 in forum WELDINGReplies: 3Last Post: 24th Oct 2020, 08:54 AM -
welding cast iron to steel
By Knotaclue in forum WELDINGReplies: 2Last Post: 8th Oct 2010, 10:11 PM -
Welding railway iron.
By goodwoody in forum WELDINGReplies: 8Last Post: 17th Aug 2010, 08:25 PM -
TIG welding cast iron ???
By kwijibo99 in forum WELDINGReplies: 1Last Post: 20th May 2010, 05:11 PM
