Results 1 to 5 of 5
Thread: hardened shaft repair
29th May 2022, 01:53 PM #1New Member
- May 2022
- Grafton NSW
- 68
- 5
Hi all, i have an Ozito brand multi head cordless tool, and the chainsaw head component suffered a snapped drive shaft due to a slight kickback. the internal components look like reasonable quality, though badly designed in not having some shear point in the design. anyhow….i am going to try a tig repair and just after some reassurance that it is possible. what filler rod would be best. i have 316L stainless and comweld high test or woul something else be better. i have ground the ends to a V in preparation and just awaiting some encouragement. it is only a home use machine but would be a shame to junk it. shaft is approximately 8mm dia.CBB8870E-E8FF-4C4A-A8E1-84B2B04CAC23.jpg483BF918-F11B-44A4-9A47-07D4FCEEE08C.jpg
29th May 2022, 04:08 PM #2China
- Dec 2005
- South Australia
- 1,657
I am not a welder although have completed very similar projects in the past I would go with hitest if you weld with any thing other than TIG you most likely need to re case harden ( in my experience being Ozito it will only be case hardened )
I assume it is past it's 5 year warranty
29th May 2022, 08:10 PM #3Tool addict
- May 2008
- 241
Alternative option, since it's Ozito, there's a good chance you could get Bunnings to special order in that part. I've done so in the past, when the cutting head in my frond chomper got chewed up.
29th May 2022, 08:49 PM #4New Member
- May 2022
- Grafton NSW
- 68
- 5
29th May 2022, 09:07 PM #5New Member
- May 2022
- Grafton NSW
- 68
- 5
Hardened Bastard
By Doctor Bungle in forum METALWORK GENERALReplies: 8Last Post: 6th May 2021, 10:43 PM -
Hardened Drill Guides
By KBs PensNmore in forum WANTED TO BUYReplies: 8Last Post: 7th Sep 2020, 09:07 PM -
Masport chipper/shredder shaft repair
By OxxAndBert in forum METALWORK PROJECTSReplies: 24Last Post: 11th Oct 2019, 05:19 AM -
Machining case hardened shaft
By Bryan in forum METALWORK GENERALReplies: 27Last Post: 3rd Nov 2010, 04:42 PM -
Shaft repair
By Bryan in forum METALWORK GENERALReplies: 9Last Post: 9th Jun 2010, 08:44 PM
