Results 1 to 2 of 2
Thread: Checking electrode tip angles?
7th May 2022, 02:33 PM #1
Senior Member
- Victoria, Australia
- 111
Is there an equivalent tungsten electrode tip gauge for checking angles similar to a thread gauge?
tom
7th May 2022, 03:05 PM #2
I have always just eyeballed it- Mostly sharpen mine on a green silicone carbide grinding wheel on a bench grinder. Grinding angles matter, broadly speaking, But you won't pick the difference between 45 degrees and 40, which would be calibrated eyeball tolerances.
You can buy commercial sharpening rigs with diamond wheels and accurate repeatable cuts- like the CK turbo sharp, but for $1500 I don't bother.
For stick out you can get tungsten stickout gauges, or just use a rule butted up against the cup.
Cutting accurate angles in RHS
By garfield in forum METALWORK GENERALReplies: 55Last Post: 23rd Jun 2017, 01:07 PM -
Thread tool angles
By Bryan in forum METALWORK GENERALReplies: 3Last Post: 24th Sep 2010, 11:55 PM -
Help with tig weldging angles.
By gozz in forum WELDINGReplies: 14Last Post: 7th Apr 2010, 04:44 PM -
Electrode positive or Electrode negative
By .RC. in forum WELDINGReplies: 8Last Post: 26th Apr 2009, 12:39 AM -
HSS Tool Angles, - Angles? What angles??
By Kody in forum METALWORK GENERALReplies: 1Last Post: 6th Dec 2008, 08:07 AM
