Results 16 to 20 of 20
19th May 2022, 04:48 PM #16Member
- May 2020
- s.w. sydney
- 53
i don,t see the point of it, can,t tell what industry its used in? are you making this stuff up, been watching too many movies.
i,ll ask the welding gods at work, we have orbital pipe welding machine , dc welding, maybe its on it. ill see if they have heard of it.
20th May 2022, 11:15 AM #17
Some information from years back.
"The electron stream is from work to electrode while the heavier positive ions travel from electrode to work - piece.
With aluminium and magnesium there is always a thin layer of refractory oxide of a melting point
of around 2000 C which has to be dispersed in other processes by fluxes by means of a corrosive
flux to enable weldability. The positive ions in the TIG arc bombard this oxide and together with
the electron emission from the plate, break up and disperse the oxide film.
This a characteristic which has made the process so successful for the welding of light alloys.
The electrons streaming to the tungsten electrons generate a great heat, so its diameter must be
relatively large and forms a bulbous end.
It is this overheating with consequent vaporisation of the tungsten and and possibility on tungsten
being transferred to the molten pool ( pick up) and contaminating it is the drawback to the use of
the process with electrode positive. Very much heat less is generated at the molten pool and
therefore this is wide and shallow."
Reference : page 375. The Science and Practice of Arc Welding by A.C.Davies
Cambridge University Press Seventh edition 1977
20th May 2022, 12:29 PM #18Senior Member
- Apr 2021
- 212
Hi Grahame,
I have the later version of that book "The Science and Practice of Welding" by A. C. Davies, volumes 1 and 2. The section to which you refer is in volume 2 on page 148.
This describes the "cleaning cycle" of aluminium etc AC welding. The function I am concerned with uses DCEP but not as part of the normal cleaning cycle. I believe it has two functions.
- Tungsten ball maintenance as described previously and
- Tungsten preheating
The electron emissivity of tungsten increases with temperature and preheating it creates a more stable arc when the trigger is pulled.
Jack
20th May 2022, 08:39 PM #19
semantics, but I think DCEP and cleaning action go hand in hand.
As for electron emissivity - which we spoke about separately, I have a hunch this is why we alloy tungsten with Thorium, zirconium, lanthanum, ytterium, cerium etc etc. Helping to create a clean arc start before tungsten reaches an ideal working temp.
21st May 2022, 12:21 AM #20Senior Member
- Apr 2021
- 212
I haven't made a proper study of the effects of alloying elements in tungsten but they do improve arc starting and stability. Improving the electron emissivity may well be the mechanism of that.
In addition though, adding alloying elements to the tungsten improves the current carrying capacity of the electrode and reduces the incidence of breakaway parts leading to inclusions in the weld.
Jack
White Water?
By bigphill in forum METALWORK GENERALReplies: 4Last Post: 23rd Oct 2013, 09:30 PM -
A Delicacy from Placentia - Kingmann White MINI-SINE Bar
By Anorak Bob in forum METALWORK GENERALReplies: 6Last Post: 11th Aug 2012, 08:57 PM
