Results 1 to 5 of 5
Thread: Ozito MWR-135
14th Feb 2022, 09:43 PM #1New Member
- Jan 2022
- te awamutu, waikato, NZ
- 70
- 3
Ozito MWR-135
Hi
i have an ozito mwr-135 mig welder (i10 years old) and am trying to source (amongst other things) some wire feed rollers for it.
However, as per the photo, it has a rather unusual roller shaft.
Does anyone know:
a) what other brand & model of welder might be similar to mine.
b) where i might source such rollers? (OD 25mm, ID 8mm, 7mm thick)
thanks in advance.
14th Feb 2022, 11:10 PM #2
Hi Moose
Welcome to the Metalwork Forums.
It is nice to see more and more Kiwis joining us.
There are lots of good people here who are ready to pitch in and help another member.
Please take the time to navigate around the our sub forums to view the varied and interesting subjects.
To do this, goto the the FORUM box in the top left hand corner of the screen and click it.
Then click Forum Home at the top of the pull down menu and a scroll down page will come up.
Scroll down the page and the various help pages and sub forums shall be shown.
Please read the Terms of Use on the very top of the scroll down page - they are our rules.
To save time here's the link
https://metalworkforums.com/f90/t197...terms-tou-read
Many pages also have a sticky at the top.If you post its always a good idea to read the sticky ,if there is one there.
Please post any questions in the appropriate MetalWork forum.
re the Ozito drive wheels.
I say its fairly likely that your Ozito drive wheels fitted could be common sizes across a range of some other brands and models.
A phone call to a NZ dedicated welding supply shop might yield a result.
Otherwise there is https://www.bobthewelder.com.au/Drive-Rollers. he had 47 items listed. <edit BTW has one listed as 25 x 7.9 x7.3-he shows dig vernier pics of dimensions)-any chance of a minor error on your spindle diam measurement ?.
or
Some of our blokes may recognise the dimensions given and be able to advise you if their machine brand and model has the same and you might be able to order them as spare parts.
I would not hold too much hope with Ozito holding spares (but you never know) I was wrong see this http://cdn2.blocksassets.com/assets/...pare-Parts.pdf -see the text and P nos might be a special order through Bunnings.
Again, welcome to our forums.
15th Feb 2022, 08:22 AM #3New Member
- Jan 2022
- 70
- 3
Hi Graham
Thanks for your suggestions.
i had been in contact with ozito tech dept. who interestingly enough tried to be helpful but due to the age of the machine couldn't.
Whilst the machine was made in China and Ozito simply put their label on it, Ozito couldn't (wouldn't?) supply the manufacturer's details. I rather suspect the original manufacturer still exists & only supplies the Chinese market (&/or Bossweld).
Local welding shops dont carry such stock (but do suggest purchasing superior machines with readily available parts).
My alternative is to use a std. slotted keyed wheel & then make up a square key....
The Bossweld wheel has the same dimensions (shaft dia on ozito is also 7.9)...but BobTheWelder only has the K style groove. Regardless, i will contact him (& Bossweld!).
moshe
13th Apr 2022, 01:55 PM #4New Member
- Jan 2022
- 70
- 3
a kudo to cigweld
Hi to anyone reading this thread.
i managed to source the wire feeder rollers.... from......cigweld!
Their older cigweld 135 is virtually identical to the ozito (including the feeder roller).
In the course of my search i also discovered that the clarke 135 (UK) & the forney 306 (USA) are also virtual identical (except for the feeder roller).
So i suspect they are all a copy of the original forney.
Regardless, i would just like to add that i have never encountered such superb technical support as i did from cigweld & would like to splash that fact everywhere.
Its seldom that one can say that one had superb technical support.
A Cigweld will be my next welder.....i must also add that this is for home/farm use.
13th Apr 2022, 02:12 PM #5
Hi moose,
Thanks very much for the feedback.
It could of great value from those who find themselves in the same boat, somewhere down the track.
Ozito MWR - 135 -- Welding current but no motor or feed
By Stan Martins in forum WELDINGReplies: 7Last Post: 29th Apr 2020, 02:20 PM -
Ozito 355mm Abasion Cut Off Saw - Katoomba NSW
By FenceFurniture in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 14th Apr 2019, 04:44 PM -
Ozito MWR-135 help needed please
By ausdier in forum WELDINGReplies: 6Last Post: 24th Oct 2018, 12:22 PM -
ozito 90 Amp Mig Welder
By Gaza in forum WELDINGReplies: 23Last Post: 9th Dec 2008, 04:06 PM
