Results 1 to 4 of 4
Thread: CIG weldskill 250 MIG
6th Feb 2022, 03:57 AM #1New Member
- Feb 2022
- Townsville, Australia
- 1
Hi all,
I have a 250amp CIG mig as a welder at home, it was working fine yesterday, then today when i powered it up, the cdc6-32 contacttor? randomly clicked on and off numerous times. I Powered down unit, then upon repowering, the fan runs but that is it. the power light on front of unit is not illuminated and the service manual says blown Primary fuse. From what i can find the machine only has the 2 circuit breakers which both test ok.
Has anyone had this issue and can point me in the right direction as to what the problem may be??
i'm reasonably handy with electrionics, and have run through and tested everything i can think of but cant find anything that seems out of sorts.
Any help to diagnose my issue would be greatly appreciated.
Cheers Dan
14th Feb 2022, 11:22 PM #2Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
A stab in the dark.....tested the contractor coil? They can fail.
I assume you have a schematic diagram for your machine?
14th Feb 2022, 11:43 PM #3
Hi Dan 67
Welcome the the MetalWork Forums
You have joined an amazing bunch of people. They are clever,skillful and collectively have an huge amount of knowledge that they share willingly.
Lots of helpful folks here here and will welcome you and offer their input and experience.
To navigate our Forums click on the FORUM box at the LH top of the page.
A dropdown menu will appear and click on FORUM HOME which will give you a scroll down page with all of our various sub forums and other helpful things on
Our forum rules, the TOU's are on top and the rest is the sub Forums and help pages that make up our forum package.Please make sure to read through them.
Anything else you need to know,please PM me and I will help If I possibly can.
15th Feb 2022, 10:38 AM #4Senior Member
- Apr 2021
- 212
I can't help with that welder but I do see that the power light is connected to the control board. That might mean there is no power to the control board or the board has failed - something to check.
Be aware that there is an unfortunate crop of the circuit diagram - the 40V shown at the bottom is actually 240V (mains).
Good luck
Jack
Weldskill 200 AC/DC (novice questions)
By Chuck92 in forum WELDINGReplies: 4Last Post: 28th Sep 2020, 11:28 AM -
Cigweld Weldskill 185
By rbr77 in forum WELDINGReplies: 17Last Post: 16th Apr 2020, 08:40 PM -
Cigweld Weldskill 150
By glivo in forum WELDINGReplies: 6Last Post: 29th Apr 2019, 06:26 AM -
Cigweld Weldskill 135
By Ziff44 in forum WELDINGReplies: 6Last Post: 7th Feb 2018, 09:29 PM -
Satincraft vs weldskill vs Ferrocraft
By jabell in forum WELDINGReplies: 14Last Post: 15th Nov 2017, 08:15 PM
