Results 1 to 4 of 4
Thread: Big Mistake
28th Oct 2021, 05:28 PM #1New Member
- Oct 2021
- Manilla
- 62
- 1
Big Mistake
Forgive me everyone I have made a huge mistake. I purchased a Rossi 130amp welder generator not realising the amperage cannot be adjusted. It has a 1000w generator and only weighs 25kg. I have a workshop full of welders and was hoping this little unit would allow me to do some onsite repairs and the odd bit of fencing. My generator is only a 6kva unit so not big enough to run a 140amp inverter welder so I thought this little unit would fit the bill. It will be ok for welding anything 4.8mm & over but a most of the time I will be using 2.5 rods on 2-3mm pipe etc. I want 70-80 not 130. Does anyone know if a potentiometer can be fitted or some other method of reducing current. The supplier is no help, only order takers with no technical advice. Appreciate any help
28th Oct 2021, 06:31 PM #2
Welcome to the Metalwork Forums
28th Oct 2021, 07:42 PM #3
Uh. Rossi.
You could probably use a resistive load bank, usually used for simulating a load on a welder for testing purposes... but I have no experience with this.
Plus one would probs cost more than the welder/generator.
Chuck her up on gumtree for a nibble and invest in something better / suited.
29th Oct 2021, 08:26 AM #4Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
Can be done, but the cost of material and labour to do so will exceed the cost of the machine. A rheostat to deal with that sort of power dissipation will be an even more costly exercise.
Like Commander said, move it along and buy something fit for purpose.
I made a BIG mistake
By SAISAY in forum METALWORK GENERALReplies: 5Last Post: 5th May 2012, 08:30 PM -
My first mistake
By Rossluck in forum WELDINGReplies: 7Last Post: 16th May 2009, 08:23 PM -
Mistake in Link
By pawnhead in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 1Last Post: 10th Jan 2007, 06:33 PM
