Results 1 to 4 of 4
Thread: Big machine, small jobs
28th Oct 2021, 02:37 AM #1
Hi chums, I have an opportunity to buy an older, three-phase, 270A welder (WIA Fabricator).
On the assumption that I bring the wire feeder and gun etc up to spec, will a heavy machine like this be comfortable running at low amps on light sheet metal, such as car panels?
28th Oct 2021, 09:04 AM #2
Your details to ID the specific machine could be more specific.
Some will others might not.
This one below does:
https://www.welding.com.au/assets/do...Sheet-2014.pdf
Theres a scad of those old WIA machines out there with a lot of variations . A model no description or picture might be of help.
Its the lower end amperage specs that your responders will be looking for.
The minimum diameter solid wire that the machine might take would be helpful as well.
Can the machine run .6mm solid wire.?
First thoughts are that it might be just a bit impractical and overkill. However if you have 3 ph to plug it into it can be used for much heavier work.
If not you will pay way more than the machine purchase price to have 3 ph installed.
It may save you time and trouble to get the model details and punch them into a search engine and get specs for it.
I would guess you have to buy a .6mm wire driver wheel as the machines I used, did not come with .6mm wheel supplied with the new unit.
29th Oct 2021, 03:11 PM #3Most Valued Member
- Sep 2010
- Lebrina
- 1,915
Extra details would be good to confirm the exact machine you are referring to. The Fabricators that I've used were well over 270A capacity but they were also some of the sweetest ru ning machines that are still revered to this day. The current WIA Fabricator is a definite backwards step in comparison. I have no doubt that the old Fabricators would have the ability to reach down and handle car panel work. Rollers for the feeder are available, but not overly cheap from memory but that would not dissuade me as the machines are bulletproof and a mate with a lathe and some 4140 bar could make a more than adequate feed roller should all else fail.
30th Oct 2021, 01:03 AM #4
Thanks guys. The exact details of the machine were not available at the time of the sale and the auction is over now, with my meagre offer not being enough to secure the unit.
Thanks Karl for sharing your experience and confidence in the older Fabricator machines, the example was nothing like the modern version. I'll keep my eyes open and try to get better details, if another one shows up..
Machine shops for small jobs in Sydney
By zcream in forum METALWORK GENERALReplies: 6Last Post: 3rd Feb 2023, 05:53 PM -
WTB Small shaping machine
By rooster413 in forum WANTED TO BUYReplies: 1Last Post: 4th Oct 2021, 11:10 PM -
Small UNC/UNF machine screws
By Ueee in forum METALWORK GENERALReplies: 10Last Post: 13th Nov 2013, 09:15 PM -
buying small Milling machine
By jackaroo in forum METALWORK GENERALReplies: 60Last Post: 27th Nov 2011, 09:50 AM -
Small machine shop job
By Legion in forum METALWORK GENERALReplies: 3Last Post: 1st Feb 2010, 06:49 PM
