Results 1 to 6 of 6
Thread: Saxozip plasma cutter
4th Oct 2021, 01:20 PM #1New Member
- Oct 2021
- Narooma NSW
- 72
- 3
Hi folks. I'm new here I have a Saxozip portable plasma cutter with a built in air compressor. It is an excellent little machine, but I believe it is no longer being made, hence I am having difficulty obtaining consumables for it. The white skirt I need in particular. A search on the net has not been productive
In Australia previously the part number for the white skirt was 0408-9272 then w000260605 and most recently w000302630 through Independent Wholesale Welding Supplies (don't sell direct to the public), but their outlets seem to no longer list them
It has the following data on a plate at the rear . CN13803 Rivoli -Verona Italy R.1.00378930234 and also Saxozip R 358515.
Any help appreciated, even an over seas supplier, and in desperation I wondered also about whether a different cutting torch assembly could replace the existing to access more readily available consumables
Kind regards
Trevor
Saxozip images.pdf
4th Oct 2021, 04:27 PM #2
Hi Trevor
Welcome to the MetalWork Forums.
I moved this post into the Welding sub Forum as it better placed to find an answer.
Theres a good bunch here and some know a lot about welder and plasma spares.
Once you get your you question answered you might like to look about the rest of the forums.
To help you find you way about the forums go to the FORUM box up in the top LH side
Click on that and select Forum Home from the list
The resulting page will show the TOUs The rules at the top.Please read them.
Scroll on down for the rest. Some pages have stickies on top with guides pertaining to advertising and similar.Good to read the sticky in those cases before ya post.
Any questions just contact yours truly. I am looking forward to seeing you on the Forums.
Again welcome
4th Oct 2021, 07:18 PM #3
You were close.
IWWS catalogue:
https://www.google.com/url?sa=t&rct=...ev5-Zh499ATYIb
IWWS distributor list:
https://iwws.net/main/?c=sb-plugin-g...&per_page=1000
Get on the blower and tell 'em what page of the catalogue, and the IWWS part number and description, and rob's your father's brother etc. If you get no joy from one supplier, cut your losses and move to the next.
I've found IWWS are good for the 'weird' stuff. Particularly when I've got NFI what it's off, and where it's from.
Unless you are shopping for a big brand and known retailer, chances are the consumable supply has a finite lifespan. Binzel, Miller, PCH, Trafimet, Hypertherm, Thermal Dynamics, etc.
There could come a time where it's more economical to put a new torch on it than continually chase parts for an old one.
6th Oct 2021, 06:42 PM #4New Member
- Oct 2021
- Narooma NSW
- 72
- 3
Fitting a different torch to the SAxozip?
Thanks very much for the help C_K. Is it possible another type of torch could be fitted to the unit ? That would simplify the problem. Also as it's fairly old, I imagine tourch design may have gotten a little better.
6th Oct 2021, 08:26 PM #5
Many have a 5/8" gas fitting for the combined power and compressed air supply. Check the type of thread you have and compare to what's out there. Realistically, the trigger interface to the machine could be cut and soldered to the new arrangement as needed. Duty cycle of the torch aside, if the nut screws on it should work.
The old nut connection was deemed a bit of an electrocution risk, so many have moved to a 'central connector' which is like a MIG gun fitting- brass centre lug bayonet, with circumferential pinouts for signal wires etc. All secure with a big plastic locking nut to draw the whole she-bang together.
7th Oct 2021, 11:16 AM #6New Member
- Oct 2021
- Narooma NSW
- 72
- 3
Fitting a new torch to the Saxozip
IWWS boss says that one of the agents I asked already, definitely should have the stock according to his records, so I'm likely to be good to go in the short term but ultimately will have to find a long term solution. Sounds like it's time for me to do a little disassembling and inspection to see what might be achievable. Thanks for all the advice, it leaves me feeling I will get somewhere eventualy
Plasma cutter ?
By morrisman in forum WELDINGReplies: 24Last Post: 20th May 2017, 08:22 PM -
Big new plasma cutter
By PDW in forum METALWORK GENERALReplies: 12Last Post: 5th Feb 2017, 10:19 PM -
Plasma cutter
By Marc in forum METALWORK GENERALReplies: 0Last Post: 28th Mar 2012, 08:37 PM -
Plasma Cutter
By Dingo Dog in forum WELDINGReplies: 2Last Post: 8th Sep 2008, 07:05 PM
