Results 1 to 4 of 4
    Sep 2006
    Australind , WA
    58
    1,281
    Default Cigweld 200 trigger spring
    Hi gents,
    Has anyone fitted a stronger spring to their Tweco gun? I think its a No 1, from approx 2004.
    I keep on accidently pressing the trigger, while moving into position.
    I looked at a exploded parts diagram but couldn't even see any 'springs'.
    I'll pull it apart on the weekend and see how it works.
    Dec 2018
    NSW
    586
    I'm a Binzel guy... but if it's anything like the binzel triggers, they are technically 1 piece according to the parts books. You could either shim it to make the existing spring firmer, or find / mod any of the 1000 different styles of springs out there to make it work with more feel. The binzel triggers I play with are just plastic hinge style assemblies, so they won't take a super firm spring before they implode.
    The easiest options would be to get some better / more dextrous gloves and be less clumsy. Eliot's Big red CRX gloves are worth a look if you are looking to upgrade. Been burning thru them of late.
    Sep 2006
    Australind , WA
    58
    1,281
    Smile
    Quote Originally Posted by Commander_Keen View Post
    What ya mean?......lol
    My gloves are fairly dextrous. Alot thinner than what we used to use.
    I'll pull the gun apart and have a look.
    They look nice. Will consider them if my clumsness doesn't improve...
    Thanks.
    Nov 2017
    Geelong, Australia
    57
    2,665
    Depending on the work/position I often use a TIG glove on my gun hand, and a heavy glove on the other. Needs to be a longer cuff/gauntlet type of TIG glove though - the short ones don’t give enough spatter protection.
    Need to be aware of what you’re wearing though - you’ll wake up pretty quickly if you grab a freshly welded part with a thin TIG glove.
  1. Replies: 7
    Last Post: 9th Oct 2021, 11:19 AM
  2. Simple trigger/hammer mechanism
    By neksmerj in forum GUNSMITHING
    Last Post: 29th May 2017, 10:33 PM
  3. Replies: 35
    Last Post: 28th Jul 2016, 02:00 AM
  4. Pulled the trigger on some Anyi gear (China)
    Last Post: 21st Jul 2013, 02:39 PM
