Results 1 to 7 of 7
Thread: Kitchen stools
16th Aug 2021, 09:09 PM #1Intermediate Member
- Jul 2021
- Central NSW
- 25
Kitchen stools
Hi forum - looking at making some square bottom kitchen stools using 30mm or 35mm shs, Was going to incorporate a back for them by making the rear legs longer, but I need to bend the shs by about 20 to 30 deg. 1.what is best way of bending them - have an old compac manual pipe bender. Or should I cut a wedge out and bend a weld?
2. Suggested method for welding. I.e. Simple butt up then mig? Or notch the joints. I am new to tig (have done little - apparently I need to do some km before I work it out…)
17th Aug 2021, 04:08 PM #2
notch and weld. bulk cleanup with a grinding wheel, then a lick up with a fibre disc to get those crisp edges.
19th Aug 2021, 11:14 AM #3
Make a form/shape to the angle you wish to bend to, you can heat bend the tube or use tube bend or clamps and heat. The angle won't be that hard to form but I suggest make the form 2 or 3 degs more as you will get spring back.
Sent from my SM-T580 using Tapatalk
Butt & weld
19th Aug 2021, 08:16 PM #4Intermediate Member
- Jul 2021
- Central NSW
- 25
You tubers seems to make a dolly to suit the shs, but have a rod tacked in the inside curve of the dolly. I think this sort of controls the kink.
Now thinking to cut the rear legs at seat height, weld the square top frame for the seat bottom then weld on the back separately at an angle. Might put some 65 x 35 across the back - where the base of the seat is, then weld the angled piece on top of that.
21st Aug 2021, 01:01 PM #5Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
The rod in the former caves the side with excess material in to make the bending easier.
Personally, I’m not a fan of the aesthetic for furniture.
I have in the past bent SHS around a former to put an incline on it like you are trying to do. I cap an end, fill it with dry sand, compact the bejeezus out if and seal the other end.
It takes a lot of heat (lots of heat, a MaPP torch won’t cut it, you need Oxy and a fuel gas) and some patience.
21st Aug 2021, 09:10 PM #6Intermediate Member
- Jul 2021
- Central NSW
- 25
So you heat and bend around the former. Does the sand stop the kinking so you get a smooth curve?
22nd Aug 2021, 03:20 PM #7Most Valued Member
- Mar 2011
- 1,555
Yes, the sand stops the tube from collapsing and maintains the shape.
On 30 or 35mm tube you’ll need a lot of heat and probably a lever.
The sand needs to be very dry, any moisture boils off during heating and creates a pressure vessel full of hot steam….bad..very bad!! I use playground sand, before I fill a tube with it I put it into an old baking tray and put it in the barbecue for a bit. The sand needs to be really compacted, I weld a plate on one end, then cut a plate a blonde one under the ID of whatever I’m bending, fill the tube with sand put the plate on top, then weld a plate with a nut welded to it on the end. Put a bolt into it then get the 1/2” rattle gun at full noise onto it until it stalls the rattle gun.
Time consuming, but you can get decent results with a 40mm thin wall tube if you can get enough heat into it. Beyond a 40 you have trouble because moving that much metal becomes very difficult. Last time I tried to bend a 50 like that the tube collapsed from the heat.
Ill go to the shed in a bit and grab you a picture of the handle on my oxy trolley, I did that the same way, smaller tube, but it’s the only thing I have on hand that’s been bent that way.
Kitchen Island Bar
By glenpinn in forum METALWORK PROJECTSReplies: 1Last Post: 13th Dec 2019, 10:03 PM -
Another Kitchen Pot Wheel Guard
By familyguy in forum METALWORK PROJECTSReplies: 3Last Post: 12th Jun 2019, 02:15 AM -
My new Kitchen, made from scrap
By Mutawintji in forum METALWORK PROJECTSReplies: 22Last Post: 18th Nov 2018, 09:39 AM -
Blackening - Not a kitchen cookup
By Anorak Bob in forum METALWORK GENERALReplies: 6Last Post: 4th Oct 2010, 08:24 PM
