Results 31 to 44 of 44
Thread: Gave this a try out
20th Jul 2021, 06:16 PM #31Most Valued Member
20th Jul 2021, 06:22 PM #32Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
make sure your generator is suitable to run a welder off. some of the small ones aren't. we fried a ESAB rebel at work with the wrong generator.
20th Jul 2021, 07:00 PM #33Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,844
Looking at these two generators below, i just hope one idles down when not loaded up defenitly can't afford a old school generator that just revs off its head from the time u start it to shutting it off
https://www.ablesales.com.au/diesel-...SABEgLNefD_BwE
If i cant run one of these big box style generators here
https://www.edisons.com.au/power/generators/
2 of these will be my last resort wired in parallel
https://www.edisons.com.au/genpower-...ping-building/
20th Jul 2021, 11:11 PM #34Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,554
Running those generators every time you want to play welder is not going to win you any points with your neighbours.. 59db at 7m is far from a silent or quiet generator.
Get a sparky to put a 15A outlet on the side of the meter box and run a 15A lead if you’re concerned about overloading the 10A circuit you are using with an adapter lead.
21st Jul 2021, 08:09 AM #35Most Valued Member
- Aug 2009
- 1,844
Racing the sparky wants $1000 to install a 15A outlet, when i had Jims Electrician install a 15A outlet 12 meters from the box in 2013 it cost $340
For $1000 i would rather buy the generator as i can sell it later and get some money back
21st Jul 2021, 10:40 AM #36
$1,000? - Tell the sparky you only want a 15A GPO, not a share of the power station!
21st Jul 2021, 01:48 PM #37Most Valued Member
- Aug 2009
- 1,844
I will call another sparky guys, my house has gas hot water and 2x 20amp lines but my laundry where i run my welders from only has a 10amp twin heavy duty outlet i'm renting and dont want to cause any problems, i will see if a good legit sparky will safely recommend just chaning the outlet to 15amps i just cant afford a 15 to be slapped in wrecklessly
22nd Jul 2021, 01:07 AM #38Novice
- Apr 2015
- Newcastle, NSW, Australia
- 17
22nd Jul 2021, 11:36 AM #39Most Valued Member
I thought the same, but the attached table from the wiring rules indicates that you could have 1 x 15A socket-outlet plus 8 x 10A socket outlets on one circuit with 2.5mm cable and a 20A breaker. The 15A outlet contributes 12A to the total load and each 10A GPO contributes 1A.
I can't find anywhere in the rules that prohibits the mixing of 10A and 15A outlets on the one circuit.
Disclaimer: I'm not a sparky. I'm not giving wiring advice, just pointing out that it might be possible and a call to a sparky worth a shot.Chris
22nd Jul 2021, 12:18 PM #40Most Valued Member
And this clause implies that a 15A socket doesn't have to be on a dedicated circuit:
22nd Jul 2021, 09:19 PM #41Novice
- Apr 2015
- 17
I may have shot my mouth of too soon, I'm not a sparky was an apprentice for while some years ago now. I did have a copy of the 2018 AS3000 but can't seem to locate it at the moment. The only one I can find on the shelf is the year 2000 one which is a little irrelevant now.
I have or had in the back of my head that you could only have 2x 15amp sockets on near a 20 Amp breaker on 2.5mm sq.
There use to be something about welders being treated as 100 percent load. But as above not sure now and probably should have not said anything.
22nd Jul 2021, 10:59 PM #42Most Valued Member
23rd Jul 2021, 09:03 AM #43Senior Member
- Sep 2009
- Newcastle
- 342
25th Jul 2021, 03:04 PM #44Member
- May 2020
- s.w. sydney
- 53
hi, bring it to my place and i can weld it up for you. i have mig tig and stick. i,m at thirlmere, s,w sydney. very experienced welder. message me.
cheers mick
My Chinese lathe finally gave trouble
By nearnexus in forum METALWORK GENERALReplies: 3Last Post: 26th Mar 2013, 03:03 PM -
I gave up at this point
By eskimo in forum METALWORK GENERALReplies: 11Last Post: 6th Jan 2011, 11:14 AM
