Results 1 to 9 of 9
    Jul 2021
    Sydney
    35
    3
    Default Voltage reduction device
    How to build a vrd tester with variable resistance
    Mar 2014
    South of Adelaide
    1,227
    With a variable resistor
    Dec 2018
    NSW
    586
    Shell out a coupla hundo for the Australian standard, I'm sure it will reference the testing method/equipment.
    Most of what I've heard abou4r VRD is what the Open circuit voltage is (can use multimeter to measure this IIRC), and a reaction time for full beans after arc is struck.
    What are you hoping to achieve by testing?
    Jul 2021
    Sydney
    35
    3
    Thanks,just curious about the function of Voltage reduction device,But i think ill save my money on the Aus standards
    Jan 2004
    Mackay North Qld
    6,446
    Hi Jay,
    Welcome to the Metal Work Forums.
    We have great bunch here very helpful and supportive of one another. You will find many like minded folk here with same interests as you.
    If you explore our pages you will find bits and pieces of interesting things all over the place.
    Go to the FORUM box at top LH corner and click on it.
    A drop down menu appears and you can select Forum Home at the top of the drop down menu list. Scan down through the pages to look at what we have.
    Please make sure read the Terms of Use -our Rules - pretty standard for many forums these days.By joining the forum its automatic that they apply to you as a member.
    Normally the soft ware works so you can't post pics or links until 10 posts are made ( or such links and pics are cleared by a mod)
    Its anti spam thing.
    There's a number of sub forums forum that might be parallel with your interest found as described above.
    If any questions contact me via PM and I'll try to help you.
    May 2013
    Rockhampton, QLD
    68
    455
    Welcome to the forum Jay.
    Jan 2004
    Mackay North Qld
    6,446
    Quote Originally Posted by JayJ View Post
    If you go to this welding Institute link the function of a VRD is described therein.
    https://welding.org.au/forums/topic/vrd/
    Jul 2021
    Sydney
    35
    3
    Thumbs up
    Thank you all..alot of knowledge on this forum,i will be doing lots of reading here
    Jul 2011
    Adelaide
    837
    Find a uni student they will have access to all the Australian Standards via their library.
  1. Black friction reduction anti corrosion at home
    By Reidy41 in forum METALWORK GENERAL
    Last Post: 18th Apr 2021, 01:27 AM
  2. Noise Reduction
    By Satwinder Singh in forum METALWORK GENERAL
    Last Post: 17th May 2020, 10:27 PM
  3. Is a con VFD output voltage
    By welder in forum ELECTRICALS
    Last Post: 12th Aug 2019, 06:59 PM
  4. Speed reduction vs. Stalling a motor vs. Horsepower
    Last Post: 26th Feb 2017, 03:27 PM
  5. VSD Hp reduction
    By Stustoys in forum METALWORK GENERAL
    Last Post: 12th Jan 2011, 02:04 PM
