Results 1 to 2 of 2
    Jun 2021
    worldwideweb
    27
    Default optimal weld geometry for tractor implement
    Hello everyone!
    I am making an undercutter/bed lifter tractor attachment. The goal is to slide a slanted board 10-12inch (25-30cm) deep into the ground and lift the soil just enough, so that you don't need to use a shovel to dig out root crops such as garlic or carrots. This is how it looks: https://ibb.co/sHxSZVS and in action: https://www.youtube.com/watch?v=xAZrUAG3PcE
    The final piece I need to decide on is how to weld the bottom lifting board to the sidewalls. There are a few options on how to do it.
    The first options is to weld the sidewalls on top of lifting board - https://ibb.co/mCwNVGM . The downside is that the lifting board needs to be extended over the sidewalls. How much should the lifting board be over the sidewall? I am thinking at least 15mm (5/8inch). Longer lifting board also causes slightly higher forces so this may not be optimal.
    The alternative is to place the lifting board between the sidewalls - https://ibb.co/0sDXLRc or https://ibb.co/7QPHkxQ or somewhere in between. Which configuration do you think is the hardest to break? Which electrodes do you recommend? The material I am using is hardox450, 15mm (~3/8inch) thick.
    Best regards
    Aug 2011
    SA
    10
    I'd go with your alternate option with the bottom of the sidewall halfway up on the lifting plate, allows for a good weld underneath as well as on top. Welding with a mig should be ok but a bit of preheat won't hurt.
  1. optimal weld geometry for tractor implement
    By potato in forum WELDING
    Last Post: 8th Jun 2021, 05:19 PM
  2. HSS Boring bar geometry
    By j3dprints in forum METALWORK GENERAL
    Last Post: 21st Jan 2021, 03:30 PM
  3. Replies: 0
    Last Post: 18th Jan 2018, 12:32 PM
  4. Fly Cutter Geometry
    By NedsHead in forum METALWORK GENERAL
    Last Post: 22nd Feb 2017, 11:06 AM
  5. Optimal table height for Milling machine
    By oohsam in forum METALWORK GENERAL
    Last Post: 22nd Feb 2014, 10:17 PM
