Results 1 to 8 of 8
    Apr 2008
    Caboolture Qld
    3
    Default Mig 0.6mm gassless wire
    I'm having trouble finding 0.6 gassless mig welding wire, got any ideas where I might source some in 1kg please. I tried eBay and no show, I'm guessing maybe 0.6 is not a gassless product, I don’t know.
    aaah the smell of wood
    Jul 2010
    9,088
    Nov 2019
    Brisbane
    69
    452
    Default 0.6mm E71 wire
    Hello from BC.
    That's the first I've seen of such small gassless wire. It could be for use in a spool gun only and I can't remember seeing 0.6mm knurled feed rollers.
    Is 0.8mm wire too hot?
    BC
    Dec 2018
    NSW
    586
    Since it's a hollow flux cored wire, it'd have bugger all actual filler material in it. Likewise I don't think I've ever seen it. Manufacturing it would be a challenge too at such a small diameter I'd think.
    What are you using it for, specifically?
    Apr 2008
    Caboolture Qld
    3
    So I gather that this stuff is not common then. I want to use it for thinner mild steel as I have reduced the current and still getting some blow through on my welds. I'm happy to admit that it could or is my welding technique as I'm fairly new to mig welding and maybe just need more practice with the 0.8 gassless wire.
    Dec 2018
    NSW
    586
    0.6mm would be rare as rocking horse...
    As for your problem, probably a bit from column A, bit from column B. Probably pushing 'it' uphill for anything under 1.6mm.
    My brothers from Weldclass have an informative informercial document outlining some considerations for fluxcored wire selection.
    https://www.weldclass.com.au/blog/18...or-0-9mm-wire-
    Lincoln Innershield NR-211MP (an E71T-11 wire) is a high quality wire similar to what you'll get out of the usual suspects. They do happen to give some useful operating parameters for their wire:
    Remember your CTWD (wire stickout) needs to be about 13mm from the contact tip where the wire comes out to the job - too close and your amps will be higher, and you'll get your burn thru. Aim to set machine to about 14V. If you don't have an accurate wire speed control, turn off gas, feed wire for 10s by timing it accurately, measure wire length, then multiply by 6 to get your m/s.
    Also mind the fume from gasless wire. Nasty, nasty cancer forming stuff you don't want to breathe in. Wear a P2 mask at minimum. Or pony up and get a bottle and weld with the best.
    Jan 2004
    Mackay North Qld
    6,446
    Quote Originally Posted by Superbunny View Post
    Welcome to our forums.
    To see what else is on offer in the rest of the forum/s do this:
    To help you explore the other areas of our forum here's a guide on to to navigate our Forum and find all the interesting places.
    Goto the FORUM box in the top left hand cnr of the page and click the down arrow. This will bring up a pull down menu that has Forum Home at the top
    Then click Forum Home which will present a scroll down page.
    Our rules,the Terms of Service are right at the top ,please read them.
    Below that are all the various areas and sub forums that make up our MetalWork forums.
    Comment on .6mm Fca wire
    You do not say what the application is for the .6mm wire. If it is car panel work I fear you work may be cut out for you.
    If you can weld in a repair panel with FCAW, you are good - and patient.
    FC runs too hot to be used easily for body panels. You'll burn through rapidly, and it gets frustrating. If you are able to, weld small ,short portions to prevent burning through.
    If the flux core is acidic,as many flux core mixes are, it can eat its way through painted panel some time later.
    I not saying impossible but I think you shall require good practice.
    Again welcome to the forums
    Apr 2008
    Caboolture Qld
    3
    Thanks guys, I have now solved my problems with welding thin steel based on your advice and now I am welding much better with success. I practice nearly every day to gain the skill needed to become more natural and ready for the day of my big project, some gates for my block, but not just any gates, they need some style. Just thought I'd thank you for your help, still using 0.8 wire
  1. Arc or gassless mig
    By Reidy41 in forum WELDING
    Last Post: 11th Sep 2020, 09:45 PM
  2. Ally gassless mig?
    By goodwoody in forum WELDING
    Last Post: 7th Jun 2013, 10:04 PM
  3. MIG Welder - Gas/Gassless?
    By Blu_Rock in forum WELDING
    Last Post: 4th Dec 2011, 11:19 AM
  4. Gassless wire quality?
    By Single-phase in forum WELDING
    Last Post: 5th Jan 2011, 06:35 AM
  5. Gassless Mig Welding
    By Com_fa_ta_bull in forum WELDING
    Last Post: 7th Sep 2009, 03:02 AM
