Results 16 to 30 of 30
7th Dec 2020, 01:03 AM #16New Member
- Dec 2020
- BKK
- 8
After few years of procrastrination, when I have decided to actually weld something, it indeed was flat. Batteries in my helmet are non-removable, so I have butchered them out and 3D printed external battery enclosure.
So now I am reasonably sure that they are still OK (and if not - don't have to buy another helmet to get fresh batteries =)
7th Dec 2020, 03:59 AM #17New Member
- Dec 2020
- BKK
- 8
Hi Grahame
Yes, I do use reading glasses.
Thank you for a load of useful information. I have just started getting my hands dirty with welding so shield is pretty fresh. I have clean the lens with microfiber, just in case, but no improvement. So, yes, that might be poor performance of that shield.
7th Dec 2020, 04:16 AM #18New Member
- Dec 2020
- BKK
- 8
Well, it looks similar, but like with much higher contrast. that is, before arc is started it looks darker and less contrasty. When arc starts brightness of the arc is making everything else goes so dark that you see the arc and sometime very faint immediate surrounding of the arc. It does not even let me see which way I should be moving the torch.
Yes, MIG is my first experience with welding.
Interesting idea. I will try to add internal removable frame with some cheap lenses.
7th Dec 2020, 09:21 AM #19Diamond Member
- N.W.Tasmania
- 1,407
Nice fix, but are your vision issues fixed as well? Well hopefully so, I must say that I really enjoy seeing a repair to something which was designed never to be repaired.
One story I have was a repair done to the torque converter of a Mercedes Benz done by a fellow who had already left the workplace before I started at a mine in Tasmania. He removed the torque converter in pretty primitive circumstances, to find that it had bad bearings, but was designed with a rolled edge in the parting plane, so was meant to be thrown away when its time was up. He took it down to the mine after hours and mounted it in a big 4 jaw chuck, and using a parting tool, separated the alloy housing, allowing him to replace the bearings and make any other necessary repairs. He then turned some spacers the same width as the parting tool, and clamped the two halves of the housing together with the spacers in between to keep all the clearances tickety boo before tack welding it up. It then remained to remove the spacers and fully weld it and job done. BY all accounts the job was a complete success, and the bearings were only a few dollars instead of an expensive Mercedes torque converter. His workmates certainly kept his name alive for years after he left them.
7th Dec 2020, 10:45 AM #20Member: Blue and white apron brigade
- 7,183
7th Dec 2020, 05:26 PM #21
Strewth... I didn't realise buying good equipment was so triggering to some. I must be such a capitalist whore.
I do believe that you get what you pay for. If not in face value, quite often pays dividends over the increased lifespan of the device.
Helmets are just like this. I work with a guy who has a mid 90's vintage speedglas. 25 years old. Used in an automotive repair environment, and later for repair of his own plant and equipment for his business. He bought quality once, shelling out for a $400 helmet in '95, whereas others would have been on their 15th cheapie at $80.
I've said it before, but you can get some very nice lenses for the old pipeliner helmets, IF you can get past the fixed shade issue. A gold omni-view lens in shade 10 is about as nice as they come IMO. So you can make it work on a budget if you want to make some concessions.
The other elephant in the room here is that if you are learning a new skill, make it as easy as possible for you to get to the top of that learning curve. Putting roadblocks to learning like crap helmet, sub-par consumables, and machinery that is not user-friendly will not be a help.
7th Dec 2020, 05:41 PM #22
The right principle...
... may sometimes not be right practically.
I agree mate, you get what you pay for, quality goes a long way and lasts a long time.
Trouble is, if it's a tool/equipment you only infrequently use, it's not for profit, and you're on a pretty tight income (read pension), you have x2 options:
No.1, buy cheap.
No.2, buy nothing.
I'm not a professional, I can't justify or pass on to a customer the cost of good stuff for many of the jobs I do. I make do.
7th Dec 2020, 06:55 PM #23New Member
- Apr 2015
- Moscow, RU
- 1
Too dark - two times?
Hi!
I've started to weld couple years ago, not MIG but stick, and I soon realized my mask is just too dark. I've little bit reverse engineered mask PCB (around brightness adjustment potentiometer) and made it "4/8-12" or "4/7-11" instead of initial "4/9-13". You can force mask to darken with sparks from lighter, and check glass darkness making photos of light bulb. You have to put camera in manual mode and measure brihtness with some graphical software.
Also I've noticed you need bright light at welding table (but not behind your head). Yes, welding arc is very bright, but probably eye can't adapt fast enough.
8th Dec 2020, 04:20 AM #24New Member
- Dec 2020
- BKK
- 8
8th Dec 2020, 04:28 AM #25New Member
- Dec 2020
- BKK
- 8
8th Dec 2020, 04:30 AM #26New Member
- Dec 2020
- BKK
- 8
8th Dec 2020, 09:14 AM #27Member: Blue and white apron brigade
- 7,183
Has that helmet ever worked?
8th Dec 2020, 01:56 PM #28Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,183
Yes!
Before I bought a cheap auto-darkening one, I used to use an old flip-down (pipeliner?), but could never strike an arc accurately - I needed to see where the rod was going.
So, I hand-held a floodlight in my other hand, nearly touching where I was about to strike.
(note, not one of the large/thin modern reflector ones,
one of the old short bulbs with a thick diffusing lens on the front,
so the splatter would not burst the bulb)
8th Dec 2020, 02:10 PM #29
So it's not just me!
The strong floodlight on the work sounds like a good idea, I'll try that. Got a very nice pair of 500 watt photofloods - that should do it (if the circuit-breaker can cope!)
Cheers.
8th Dec 2020, 03:48 PM #30
Hi plm and a welcome,which is a long time overdue since your join date in 2015.
First up however is the housekeeping where I must tell you about the MetalWork Forums layout and its rules.
go to the FORUM Box in the above top LH corner (under the sparks graphic) and click and a drop down menu appears.
If you click of the top title Forum Home and scroll down, all of our sub forums and help pages are listed. Please read our Forum Rules, called the Terms Of Use -TOU's for short.
We request that members read the TOU's and abide by them.Our TOU's are at the very top of the list.
Perhaps you can tell us more about you in the Welcome wagon forums.
We love to hear about our new members, metal working and related hobbies and interests and tools, machines, sheds / workshops, man caves or what ever you call your workspace.
Personally,I am an avid follower of some of the Russian DIY er Utubers and admire their ingenuity with clever solutions to metalwork problems where they don't have ready access to commercial supplies and work from the scrap pile.
Welcome to the forums.
Auto darkening mask not darkening fix
By rusel in forum WELDINGReplies: 5Last Post: 29th May 2016, 02:55 PM -
Double banger - Duragal removal and breathing mask for welding
By twebb01 in forum WELDINGReplies: 5Last Post: 21st May 2015, 09:35 PM -
$100 Welding Mask recommendations
By DSEL74 in forum WELDINGReplies: 12Last Post: 21st Sep 2014, 10:41 AM -
best welding mask?
By Goldfields in forum WELDINGReplies: 7Last Post: 23rd Aug 2010, 02:21 PM -
Welding Mask
By 19brendan81 in forum WELDINGReplies: 29Last Post: 13th Aug 2009, 07:21 PM
