Results 1 to 5 of 5
    Jun 2020
    Brisbane
    54
    41
    Default CK Worldwide alternatives in OZ??
    Hi, looking for some assistance please. I am very new to TIG welding (Teaching myself from Youtube... of course, haha) I purchased a Unimig 200 AC/DC and am very happy with it, however I would like to try a different torch from the one that came with it (T2 torch) I would like to try a series 9 or 17, I also need to get a switch with it as I don't use a foot pedal. Does anyone know where to buy a CK one in OZ that is compatible with my machine or a suitable alternative. Cheap would be good
    Dec 2018
    NSW
    586
    Unless you have smaller work ton do, avoid the 9 series, as it's only good for 90A.
    17 will be way more suitable for the range of ourput for a 200A machine, with less risk of burning the torch up.
    What I've done before for my particular machine(s) is this:
    1) Get the torch you want- I like CK. You can get them online, or via BOC on an order in job - they can get pretty much all the CK torches and parts, and it's quality gear, not the chinese knockoff junk.
    2) Get yourself a button, rotary dial, pot slider etc that works with your machine - cut off / re-solder or buy a new plug body to suit your machine.
    3) As janky as it sounds, velcro or tape the button of your choice to the torch handle body (CK's are easy, as they are just a round plastic barrel). Way I look at it, it is easily moved if you need to do something out of position.
    4) Stick all parts in a zip up or velcro cable cover for protection, or leave them loose with periodic zip ties to stop them tangling. All you need for TIG is power, gas and any signal wires for the button. Some "1-piece" torches have gas running thru the middle of the copper power cable.
    I have a number of CK torches and use them over the unimig 'SR26' (binzel knockoff) style torches almost exclusively. I have a 17 series superflex which is just a dream to use.
    The CK benefit as well is running the dinse 'safe lock' enclosure on the machine, and having the ability to easily switch out torch cable packages with a spanner. Can do the same on the business end with the torch bodies, handles etc. It's all modular.
    Get at it, tiger!
    Nov 2019
    Brisbane
    69
    452
    Default New to tig
    Hello Stoobydale.
    To advise on a torch you need to think about the work you want to do. T17 torches are rated at 150A @ 50% T26 torches are 200A @ 50%. There are 2 good brands available in Aus. that are usually in stock. Binzel and Tigmaster. Neither is cheap. We sell a few of their torch heads each month to replace cheaper designs.
    If you want to PM me I have some plastic lever switches with leads you can have for $0.00. they are held on the handle with 2 cable ties. This would need a torch with a tubular handle. Your existing torch may have 2 types of control plug, 7 or 9 pin. You will need to specify this if buying a torch or parts.
    To me Youtube has 2 outstanding sites for tig info. Weld.com and Welding tips and tricks.
    BC
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    CK Worldwide will post to Australia directly too. You just have to ask. They don't advertise that.
    Cheers, Joe
    Apr 2020
    Melb, Vic
    12
    I recommend Oz Welding Supplies. Based in Tas. Some things are little dodgy (e.g. some kits just use eBay quality) and the language used on social media is questionable, but I have multiple torches and cups and quality is great.
  1. Is lathe bed grinding available in Brisbane? Any alternatives?
    By j3dprints in forum METALWORK GENERAL
    Last Post: 12th May 2018, 06:18 PM
  2. Alternatives to stainless acid pickles
    By Michael G in forum WELDING
    Last Post: 18th Jun 2017, 10:44 AM
  3. Welding Alternatives.
    By soundman in forum WELDING
    Last Post: 8th Oct 2014, 10:35 AM
  4. Anodising or alternatives in the shed
    Last Post: 3rd Jun 2012, 03:13 PM
  5. Woodworking Forums Worldwide
    By Rocker in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 15th Jul 2004, 06:57 PM
