Results 1 to 4 of 4
Thread: Repairing malleable iron
23rd Oct 2020, 12:03 PM #1Senior Member
- Brisbane
- 143
Hi all ...I have these brace jaws that I want to repair.. I assume they are malleable iron.. easily bent and straightened.
What would be the best plan of attack.. make a new part and braze it on.. or build up with either nickel rod or brass ?
23rd Oct 2020, 11:37 PM #2Golden Member
- Dec 2011
- 505
If it's brace chuck jaws you have there, steel is more likely than cast iron, in which case some sort of welding would be in order.
A traditional approach may be forge welding (think blacksmithing), though I wonder if those jaws would be too small for that.
I have not seen brace chuck jaws with holes in them - were they modified for special work?
Bill
24th Oct 2020, 07:40 AM #3Senior Member
- Brisbane
- 143
The small hole is for the spring to pass thru.. the larger had a stepped pin ...presumably for alignment.
24th Oct 2020, 08:54 AM #4Senior Member
- Oct 2015
- melbourne
- 473
If it was me, I'd just build up with braze, then shape.
Maybe a Nickel bronze rod.
Too small for me to even think about forge welding, that needs a good overlap not a but weld.
Tig with the right filler maybe?
When does cast iron not machine like cas t iron?
By simonl in forum METALWORK GENERALReplies: 20Last Post: 31st Jul 2018, 08:57 PM -
Checking and Repairing
By scottyd in forum METALWORK GENERALReplies: 6Last Post: 26th Jan 2016, 08:22 PM -
Cast iron fireplace - Question for restoring using Penetrol & Liberon Iron Paste
By mookschank in forum METALWORK GENERALReplies: 8Last Post: 19th Jun 2013, 06:32 PM -
repairing an anvil
By kraits in forum METALWORK GENERALReplies: 5Last Post: 30th Jun 2011, 11:06 PM -
Repairing Cast iron
By Godzilla98 in forum METALWORK GENERALReplies: 6Last Post: 6th Apr 2010, 11:03 PM
