Results 1 to 8 of 8
Thread: Welding helmet problem
24th Sep 2020, 09:35 AM #1Member: Blue and white apron brigade
My "best" welding helmet is one I bought from Hare and Forbes about 5 years ago. It has similar specs to the ProMax500, eg 4 sensors and dual shade range, and I liked the comfort and viewing angle it provides. I don't do a lot of welding and when I used it a few days ago I notice the switching speed was on the slow side and adjusting the switching speed made no difference. I thought it might have been due to a flat battery so I left it in the sun for a day but this made no difference.
The really noticeable slowness in switch speed is when the arc stops and it takes about 3 seconds to restore no shade status. Unlike the Promax500 the switches etc are on the side of the helmet so I wonder if the switch speed pot is just dirty?
Apart from buying a new one any idea what can be done?
24th Sep 2020, 11:06 AM #2Senior Member
- May 2010
- 135
BobL,
couple of things I've found over the years...
#1 - the batteries in these helmets are standard coin cells, and are not rechargeable. The solar panel is really just reducing load on the battery, but not actually charging it.
#2 - the coin cell batteries in the "non replaceable "solar charging" units are standard batteries, with welded battery tabs. If you open the unit, you can change out the batteries and simply solder new connections to the tabs.
I've done that with 2 helmets I've used over the years, and in both cases it bought additional years of use. I made the mistake of cobbling up a 4x AA battery pack with my first unit.. the batteries worked fine, but the weight in the helmet was wrong, and the AAs would leak long before I'd flattened them with use.
The last 2 helmets I've bought have both had replaceable batteries. Again they are simply coin cells, but located under a cover with spring connections. One was around $150 online (rebadged), the other a ESAB sentinel.
Hopefully that helps
Des
24th Sep 2020, 11:27 AM #3Member: Blue and white apron brigade
Thanks Des - it does indeed help.
I found the battery - a CR2450 cell - surreptitiously hidden in the inside of the helmet with "battery" very faintly embossed on the slide on/off plastic cover - I'd never see in before. Battery is dead flat (well -0.1V) hopefully a new one will sort it.
24th Sep 2020, 02:56 PM #4Senior Member
- May 2010
- 135
25th Sep 2020, 03:34 PM #5Member: Blue and white apron brigade
Finally got round to installing battery - all good.
26th Sep 2020, 12:00 AM #6Most Valued Member
Some welding masks have an on - off switch or one that switches between "weld and grind"
Switching to grind when finished welding for the day or more helps with the life of the battery. Mine lasts about 12-18 months.
26th Sep 2020, 10:15 AM #7Member: Blue and white apron brigade
26th Sep 2020, 05:49 PM #8Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,554
Welding Helmet Fogging Up
By Oldneweng in forum WELDINGReplies: 10Last Post: 30th Jul 2016, 09:06 PM -
For those in the hunt for a AD welding helmet
By garfield in forum WELDINGReplies: 7Last Post: 21st Jul 2010, 07:19 PM -
speedglas welding helmet
By Rossluck in forum WELDINGReplies: 11Last Post: 4th May 2010, 10:44 PM -
Welding Helmet Help Required
By Watts2759 in forum WELDINGReplies: 15Last Post: 27th Jun 2008, 01:10 PM -
Welding helmet repair
By Andy Mac in forum METALWORK GENERALReplies: 3Last Post: 26th Jun 2007, 02:11 AM
