Results 1 to 15 of 26
Thread: Arc or gassless mig
6th Sep 2020, 01:04 PM #1Golden Member
- May 2020
- Willowbank QLD
- 517
Arc or gassless mig
Hello readers
I have a tendency to overthink things which can then lead to limited progress. This has been the case with getting a welder and learning to use it.
So in an effort to combat that I thought I should learn to walk and seriously think about what I will be welding. I have come to the conclusion that as a beginner it will be limited to general home welding such as a gate, shade structure, maybe a steel work bench and such.
Therefore the two economical options appear to be an Arc welder or a gassless mig.
Arc seems old fashioned and therefore mig is the way to go. But as I have aged I have become to realize that older technology can be highly suited to home use.
So if you were after an economical welder for general duties that will be only used occasionally which way would you go and why?
6th Sep 2020, 01:52 PM #2Philomath in training
- 6,540
I'd go stick. Gasless MIG was a bit of a disappointment to me, as there was more spatter than I wanted to see. Bunnings and others 'sell' gas cylinders though, so gased MIG is possible without ongoing rental costs. The other nice thing about modern inverter supplies for stick is that they can be used for DC TIG if you buy the extra bits.
6th Sep 2020, 02:00 PM #3Most Valued Member
Totally agree with Michael.
Until recently, in my shed I had a choice of gasless mig or an old AC arc welder.
Being home use i could never justify the gas for mig, however I too was disappointed with gasless mig for the same reasons Michael outlined.
However, about a year ago I bought a modern, reasonable quality DC inverter arc welder and I love it! So much easier and very forgiving.
I have successfully welded 0.8mm stainless sheet with 1.6mm stainless rods with a bit of care.
My gasless mig has spiders living in it!
$360 bought me a great welder from a family owned company.
6th Sep 2020, 03:33 PM #4Diamond Member
- Aug 2006
- 1,105
If you are going to buy the cheapest mig you can get your hands on and run gasless wire through it don't bother as you will have nothing but problems.
Gasless can work really well but you need to run it through a decent welder.
I'd look into buying a low cost DC Inverter arc welder. Can buy one for under $200
6th Sep 2020, 07:02 PM #5Senior Member
- Oct 2019
- Tasmania
- 53
- 149
We all know opinions are like backsides.....so I have my own as well
Forget the stick and gasless and just invest in a mig with gas........easy to use and you will be happy with the results
6th Sep 2020, 07:13 PM #6Most Valued Member
- 2,651
Arc or gassless mig
Definitely stick. I suffered through 2 cheap MIGs before giving up and buying a decent one. Cheap MIGs suck!
For occasional use having a decent MIG is pointless and for the odd bit of welding here and there a stick welder basically has no running costs. A $30 box of electrodes will likely last you many years.
Spend $150-$200 on a reasonable welding helmet and you’ll find it much easier to learn too.
6th Sep 2020, 07:17 PM #7Diamond Member
- Aug 2006
- 1,105
6th Sep 2020, 07:22 PM #8Senior Member
- Oct 2019
- Tasmania
- 53
- 149
Possibly, but for me its like anything in life thats worth while......after the initial investment (buying the bottle) IMHO he will long forget the cost and enjoy the benefits of using a mig with gas. Personally I couldn't think of anything worse than using a stick or gasless even for the odd occasional use.
6th Sep 2020, 07:33 PM #9
If you want to stick metal together- either will work.
If you want it to look good early on in the learning curve, then get a mig and run a solid wire with gas.
Stick welding can get some very nice results, but it takes a lot of practice.
I wouldn't recommend buying a 'cheap' machine, get the best you can afford. It will pay for itself in better arc characteristics, safety, and end results.
6th Sep 2020, 09:17 PM #10
8th Sep 2020, 11:03 AM #11Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
Get a MIG, buy one that has capacity to run both gas and flux core and can run a 5kg spool minimum. Easier to get good results earlier in the learning curve consumables are cheaper in larger rolls. Stick electrodes aren’t cheap, and require care in storage if you aren’t going to turn them over frequently. A MIG also allows you to weld thinner material without leaving gaping great holes in it. A 1.6mm wall fence post is relatively easy to weld to with a MIG, not so much with a stick welder.
A slight off topic, but kind of related to decision making processes on using gas...
I ran my first MIG on a diet of flux core for about 5 years because ‘gas was expensive’. Then I did some research and found out gas wasn’t actually all that expensive, more a matter of perception.
Welding is an industrial process and as such has a price attached. People frequently get hung up about the cost of a rental bottle, which is around $200/yr for a D bottle. My take on cylinder rental, it’s like a supply charge for water, natural gas and electricity or the infrastructure charge for sewer, both BOC and SupaGas offer small cylinders on low turnover annual rental deals for the home gamers that work out to about the equivalent cost of a small takeaway coffee a week ( my oxy set up is on this plan from SupaGas, because I don’t turn them over very often). Yes Bunnings offer gas ‘rent free’ but you have several hundred dollars of cash tied up in a deposit, and there is every likelihood that you may not be able to recover it should they change suppliers or dispense with the product completely as has happened with a couple of other tool store ‘rent free’ cylinder exchange products.
The other consideration around using gas is the cost of consumables, small home gamer rolls of flux core are poisonously expensive if you compare them to the cost of regular wire. 5kg of ER70 wire is about $30, a 900gm roll of flux core is around $18. If you go through 5kg of wire a year, half your gas rental is paid for.
Welding, and most metal working in general for that matter, is a case of you have to pay to play, the amount you are prepared to pay, will to some extent determine the results you get. A cheap flux core mig will join metal together, but it won’t do it anywhere near as elegantly as a machine capable of running gas which will cost a bit more.
Back to scheduled programming
8th Sep 2020, 11:06 AM #12Senior Member
- Oct 2019
- Tasmania
- 53
- 149
Sorry to be a little off topic but I havent paid for gas bottle rental for several years now.
Quite a few suppliers allow you to buy them outright or in bunnings case pay a refundable deposit when or if you ever return the bottle.
8th Sep 2020, 09:35 PM #13
People conveniently dismiss the importance of the deposit. No one considers the opportunity cost of what that money could go towards, or what that deposit could become (inventory, and subsequent revenue).
Gee, just having a facebook post saying '$50 bucks for an odd welding job' would net a profit on gas costs after all was said and done... or at least keep the beer fridge stocked.
9th Sep 2020, 05:16 PM #14Golden Member
- May 2020
- Willowbank QLD
- 517
Thanks for all of the feedback so far. I have no doubt that a Mig with bottle would give a better weld than the other two. Like most of you I have a shed that is fixed dimensions. Yes I could build a bigger shed and than have more space, but then I would soon fill that, funds permitting.
The other thing is we all have our skill sets. I think it would take me quite a bit of welding before I would be happy with the look and structural interrogatory of my welds that I fully trust them. Therefore for jobs that I really don't want to fail I know a few people that are not just welders but true craftsman.
I am leaning towards an inverter arc welder. I also like the idea of a Tig attachment down the track. If it works out that I don't have the ability to do Tig welds that I am happy with I still have the arc welder. If by some miracle I master Tig I can get a good Tig welder.
Recommendations of arc/tig welders would be appreciated. I only have single phase but could put a 20 amp plug in if necessary.
9th Sep 2020, 06:17 PM #15Most Valued Member
After some forum members reccomended Magnum Welders I bought a 200A arc/Tig inverter welder from them. At $360 (from memory) it's not the best or the cheapest but I have been very happy with it. I even took it apart and did a review on it See here:https://metalworkforums.com/f160/t20...agnum+inverter
Ally gassless mig?
By goodwoody in forum WELDINGReplies: 6Last Post: 7th Jun 2013, 10:04 PM -
Gassless mig / Porosity
By BigPete1 in forum WELDINGReplies: 2Last Post: 10th Feb 2013, 11:47 PM -
MIG Welder - Gas/Gassless?
By Blu_Rock in forum WELDINGReplies: 16Last Post: 4th Dec 2011, 11:19 AM -
Gassless wire quality?
By Single-phase in forum WELDINGReplies: 5Last Post: 5th Jan 2011, 06:35 AM -
Gassless Mig Welding
By Com_fa_ta_bull in forum WELDINGReplies: 8Last Post: 7th Sep 2009, 03:02 AM
