Results 16 to 19 of 19
7th Sep 2020, 08:45 PM #16Diamond Member
- Aug 2006
- 1,106
The speedglas 100V is pretty good value at $249
https://weldinghelmetsonline.com.au/...SABEgJadfD_BwELast edited by Com_VC; 7th Sep 2020 at 08:45 PM. Reason: link added
23rd Sep 2020, 02:33 PM #17Senior Member
- May 2010
- 135
started life with hiderock then moved to sub $200 (Auto1 from memory) autodark about 15 years ago - it failed with 5 years of sweat dripping into the back of the unit
Then moved to another sub $100 one from ebay - failed pretty fast due to heat and sweat - I cobbled together a working unit using the last 2 helmets, some batteries, and lashings of hot glue....
Bought a $150 unit (can't recall where) and it still works, but the harness and tension is weak, with the helmet often falling down or moving mid weld. I'd already modified the harness (Old hiderock), and added a detachable cloth hood to prevent sunlight coming in from behind. This unit was the first with removable/ replaceable batteries, and it's now a stipulation in all units I look at.
Since the helmet above was starting to have glitches with the harness, I was eyeing off one of the Lincoln units with the large window, true colour, etc. When my wife went to buy it for me, she came home with an ESAB A50 sentinel.
The sentinel has been in use now for over 12 months, and I certainly can't complain about it - works well, and is very comfortable. The digital controls are easy to use (not that I touch them often), and the layers of lenses are great for protecting the element. The helmet is starting to "flop" a little, and I['m hoping it will be an easy fix.
The only thing with the sentinel is that the face is so "round" - I have to be really careful when I put the helmet down on a bench that it doesn't roll off.
7th Jan 2021, 06:44 PM #18New Member
- Oct 2020
- Australia
- 27
- 1
I have been using Michigan XL View Pro for 2 years. It's pretty good
8th Jan 2021, 05:43 PM #19Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 456
Welcome to the forum.
TIG welding helmets
By Pete F in forum WELDINGReplies: 91Last Post: 9th May 2011, 10:11 PM -
BOC welding helmets on special
By gallegos in forum WELDINGReplies: 3Last Post: 22nd Feb 2011, 11:33 PM -
Tecmen welding helmets
By BobL in forum WELDINGReplies: 39Last Post: 13th Jul 2010, 05:37 PM -
Welding Helmets
By waz in forum WELDINGReplies: 11Last Post: 20th May 2010, 08:18 PM
