Results 1 to 5 of 5
    Feb 2012
    australia
    1
    Default Token tools Alupulse 210 Pro - who's got one?
    Hi all,
    My original (circa 2007) Token Tools 200a AC/DC TIG is slowly on its way out, so I'm looking to upgrade.
    https://weldingstore.tokentools.com....welder-210pro/
    The different AC waveforms on top of standard square wave, and a AC + DC hybrid mode is very appealing, as I do a lot of thin aluminium.
    Programmable memory slots are a big plus, but not sure how many there are.
    I did find that the waveform selections for AC and duty cycle are the same as the Miller Dynasty 210 DX.
    Who has one?
    What don't you like about them?
    What is great about them?
    Worth the $2700 with the foot control?
    Cheers!
    7,188
    Yep I have one. I don't use it a lot but it has never disappointed.
    The only problem I've had was an overly tight fitting bayonet on one of the cables which I was able to fix with two swipes of a file.
    I love the memories - saves a lot on my own.
    Mine has 8 - I think.
    With an Ar reg, std torch and pedal (still haven't used it) mine cost $1800 5 years ago.
    Yes I would buy another.
    Sep 2016
    mandurah wa
    75
    10
    I've got the 215 Multi process model , which has the combined plasma cutter, I had a minor issue with the hf start but a quick call to Pete at Token and he ran through it with me to find I had a slightly out of adjustment points.
    No issues since but have only used for aluminium so far. IMO a good machine with great back up if needed.
    Apr 2013
    Mornington Peninsular
    23
    I also have the 215 multi process - I already had a plasma cutter, but it wasn’t much more and now I have two!
    I also got the foot control and the mini torch. This is great for light work - it’s almost like a pencil with a very light cable.
    No problems in 5 years.
    Sent from my iPad using Tapatalk
    Jul 2006
    Athelstone, SA 5076
    4,258
    I have one but am still learning how to use it...or in other words I still cant do nice TIG welds...plasma works great
  1. Replies: 6
    Last Post: 1st Oct 2018, 11:38 PM
  2. Token tools welder
    By eskimo in forum WELDING
    Last Post: 18th Aug 2017, 09:01 PM
  3. Token Tools MMA selection - need help!
    By twebb01 in forum WELDING
    Last Post: 18th May 2015, 07:00 PM
  4. Token tools cyber sale
    By mac_man_luke in forum WELDING
    Last Post: 1st Dec 2014, 08:25 PM
  5. Token Tools Alupulse 200 AC/DC Tig Welder
    By steran50 in forum WELDING
    Last Post: 14th Mar 2011, 12:24 AM
