Results 16 to 25 of 25
Thread: My welders are breeding.
7th Aug 2020, 09:32 PM #16Pink 10EE owner
- 6,218
You are not suggesting my $2/kg retail price 6013 Permanent Brand chinese welding rods are to blame?
I hope I do not have to change welding rod brands.Gold, the colour of choice for the discerning person.
7th Aug 2020, 10:05 PM #17
I was leaning towards blaming the Unimig.
7th Aug 2020, 10:32 PM #18Most Valued Member
- Sep 2010
- Lebrina
- 1,915
The minimum OCV specification for electrodes only comes into play when running AC current as it allows the arc to reignite after the 0 Volts portion of the AC cycle. A DC current will run an arc with a bare wire, in fact early arc welding electrodes were just that, bare wires and yes they did produce porosity.
Some VRD's are able to be turned off, while others are able to be set to a different level by internal switching and then some cannot be altered at all. To be honest, most VRD difficulties are caused by either poor earthing or even more commonly, simple lack of familiarity with VRD equipped welders. Keep persevering and it will get better.
8th Aug 2020, 08:47 AM #19Pink 10EE owner
- 6,218
Some testing of other rods yields the following results.
6011's seem to strike fine.
6013's are a bit crap.
7014's seem fine.
7016's a bit stickier, but they are sticky at the best of times.
8018's, see 7016.Gold, the colour of choice for the discerning person.
2nd Oct 2020, 08:52 PM #20Pink 10EE owner
- 6,218
I am certainly no expert on stick welding, and vertical up's, I have always found difficult. Having had to do some today, the unimig really seemed to have made the outcome better. I am not going to be doing any pipeline work anytime soon, but they are strong enough. They were WIA 16TC rods. 3.2mm at 75 amps. I do like this welder. I still do not like the VRD, but the welder works really well.
The project was my tipping trailer. The rocker roller hanger was never reinforced when built at the factory and I found it had ripped itself off. I think my fix should be strong enough.
20201002_082918.jpg 20201002_134546.jpgGold, the colour of choice for the discerning person.
3rd Oct 2020, 01:04 AM #21Most Valued Member
Nice VU's, I don't like doing them either. Another alternative, would be to weld flat plates about 50-60mm long, either side of the hanger on the underside along the chassis rails. Just for interest sake, what was the thickness of the chassis rail, please.
3rd Oct 2020, 07:12 AM #22Pink 10EE owner
- 6,218
It is 3mm thick 150mm X 50mm, with another 150mm X50mm on top of it for the tipping tray. I would have thought it should have been 4mm being a 3500KG trailer. My brother has an identical trailer from the same manufacturer, except his is a couple of years older. On his the middle hanger has been reinforced at the factory.
3rd Oct 2020, 08:15 AM #23
Hi RC.
For someone who has difficulty with the vertical up position weld and probably doesn't do a whole lot lot of them, I am saying you have done good mate!
3rd Oct 2020, 09:49 AM #24Pink 10EE owner
- 6,218
Thanks, I have been watching quite a few Welding Tips and Tricks videos. I have used a triangle technique.
3rd Oct 2020, 12:50 PM #25Diamond Member
- Jun 2010
- Canberra
- 1,322
That broken hangar looked like it was welded on 3 sides?
Oh, and nice repair.
MIG welders - which one to buy
By MORRIMATE in forum WELDINGReplies: 14Last Post: 30th Sep 2016, 07:08 PM -
Any can welders?
By AxelVK in forum WELDINGReplies: 5Last Post: 22nd Feb 2013, 07:55 PM -
Old vs New Arc Welders
By newbyangler in forum WELDINGReplies: 26Last Post: 12th Mar 2011, 04:22 PM -
10 Amp Welders
By Sawmaster in forum WELDINGReplies: 21Last Post: 5th Apr 2010, 04:34 PM -
Welders
By XXXX in forum WELDINGReplies: 12Last Post: 11th Dec 2007, 07:03 AM
