Results 1 to 3 of 3
    Jul 2020
    landsborough
    41
    1
    Default Trans Mig 195 Approx Value Please
    Hi Members im new to Welding and have started buying fixing and selling ,
    I have now a Trans Mig 195 and am wondering if someone can assist with an approximate value ? Approx 5 years old and seems to work fine apart from needing a new liner which i will replace asap . Any thoughts on value appreciated . Thanks In Advance .
    Nov 2019
    Brisbane
    69
    452
    Default Transmig 195
    Quote Originally Posted by aaron_sproule@h View Post
    Hello from BC.
    A Transmig 195 would be over 20 years old by now. From memory came in 2 models. 1 with a Tweco 1 torch hard wired and a Rural pack with a Tweco 2 torch. If it doesn't have a lot of guts it might have blown output capacitors which was common if 0.9mm wire was used. Resale value is a bit sad as the inverter migs run rings around the old machines. $400 on Ebay.
    BC
    Aug 2006
    1,106
    If you think it is approx 5 years old are you sure it is not a Transmig 190?
    Quote Originally Posted by steamloco1954 View Post
    Hello from BC.
    BC
    Also some of them you could only run gas not gasless wire.
    I think they may have came out in the late 80's so quite old now but well made.
  1. Drummond 'geared flywheel' lathe approx 1912
    By WCD in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 25th May 2020, 01:04 PM
  2. Small Piece of Brass Approx 100x25x3mm
    By joez in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 30th Jul 2010, 11:39 PM
