Results 1 to 5 of 5
7th Jun 2020, 06:57 AM #1
MIG welding wire recommendation needed
Hi everyone,
I am a self taught TIG welder and I am pretty good if I am allowed to brag a bit.. My walking the cup action is very consistent and my welds turn out just fine and nice..
However I need to do some MIG welding now. I know how to MIG weld but I don't have many hours behind it. Maybe 80h of MIG welding work tops.
A friend of mine asked me to weld him a frame from regular box mild steel sections. He recently purchased a small MIG welder but he doesn't really feel confident to do it himself. However he forgot to buy the MIG welding wire .
I can easily weld that frame for him but I can not use my TIG welder because its a heavy machine and he lives in a different town so the only option is for me to use the MIG he bought recently. This is also not an issue because I will weld that frame in place in no time.
But I was wondering which welding wire to buy? Before when I was doing MIG I had some generic wire provided for me and it wasn't really good. It felt quite inconsistent so I would like to buy something better for this job. He is a friend so I want to do this right . I read here https://weldingpros.net/best-mig-welding-wire/ that they recommend some INEFIL wire but I am unsure of it. Did anyone use it?
I am actually torn between Hobart's wire and this INEFIL's wire. For Hobart I am sure that it will be good but I would still like to ask for the opinion.
Also which brand would you recommend? I am highly open to suggestions!
I will probably need a small spool of 0.030" or 0.035" but even if I have to buy a big spool it is also not a problem. I will gift the rest of the wire to him to learn how to weld
7th Jun 2020, 12:10 PM #2Most Valued Member
- 5,945
As you are in the USA and this is an Australian based Forum, we don't have the same brands of wire as you do, apart from Lincoln and Hobart I think.
Going by your Link, I'd say either of your choice would be fine for what you're wanting to do.
HTH
8th Jun 2020, 07:56 AM #3
8th Jun 2020, 03:04 PM #4
Just stick to a reputable brand that is AWS ER70S-6.
You can shop down on price if you need to, but it's all pretty much the same stuff.
If you were going to use FCAW, then Select Arc make good stuff, I've used a rebranded product over here and it's quite good.
11th Jun 2020, 09:58 PM #5Member
- May 2020
- s.w. sydney
- 53
i agree with C Keen, yes the reputable brands you should do fine.
tig is my jam, you got a name, or i call you bill?
anyway , you haven,t talked about the job much, about the frame. what is it made of? ie section and thickness?
what machine have you got, and is it 120v? , in Australia we have 240v and also 3 phase (thats 415v).
cheers mick
MIG gasless welding - wire sticking inside
By Lyle in forum WELDINGReplies: 9Last Post: 12th Apr 2011, 03:24 PM -
Welding Advice NEEDED....
By Howiee in forum WELDINGReplies: 6Last Post: 14th Apr 2009, 11:08 PM -
Welding Penetration, advice needed.
By Stufart in forum WELDINGReplies: 12Last Post: 15th Apr 2008, 07:20 PM -
Duragal - Gasless Mig Wire Recommendation
By dazzler in forum WELDINGReplies: 6Last Post: 16th Dec 2007, 02:08 PM -
Bandsaw Welding Advice Needed
By nexusone in forum METALWORK GENERALReplies: 8Last Post: 20th Jun 2007, 11:13 AM
