Results 1 to 9 of 9
    Dec 2005
    South Australia
    1,656
    Default Stick welding and stubs
    The other day I was looking on as an acquaintance was doing some stick welding, every time he finished a run he changed the electrode weather it be only half used or or not.
    this person has been employed as a welder for at least 20 years that I know of, is there some reason to do this or is it just a strange quirk he has.
    When I weld at home I use the electrode until is virtually gone.
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Would they of been able to get the desired run length from the partially used rod ?
    Dec 2018
    NSW
    586
    Main factor is - who is the guy buying the rods?
    Although some rods do re-strike better than others. Some 7016's can be quite cantankerous with a hard glassy flux cap over the tip. I'll usually scratch it on a file to remove it without too much flux damage.
    Or for a plot twist- Maybe in 20 years he hasn't mastered the ability to restart a weld and tie it in.
    Jan 2004
    Mackay North Qld
    6,446
    I agree with Commander Keen above but I think there is something else to add.
    On the shop floor as a young tradesman, I saw welders who wasted like electrodes that. I think that they were not positioning their arms/hands adequately to accommodate the changing length of the electrode.
    Taking a straight fillet bead as an example ,a good welder should be able to keep the offset and drag angle from start to finish during the progression of the weld.
    I surmise they were not locking their wrist which buggers up the angles as they swivel through the limited arc of wrist movement.
    As the electrode becomes shorter it become more difficult for them to maintain the angle and as a result they stop prematurely and change electrodes.
    As an young apprentice in the late sixties the instruction from the foreman was to drop the stubs in a can and he counted them. Woe betide me if any were too long.
    The practice is wasteful in terms of electrode cost and time lost through unneeded electrode change, chipping flux and electrode restart. On a big job the waste is considerable.
    Mar 2014
    South of Adelaide
    1,225
    If you work to welding procedures you cannot restart a rod once you have stopped*, he is probably just in the habit of getting a new rod each start.
    *cant for the life of me remember why, but think it has to do with the coating of the tip of a new rod reducing impurity's.
    Jan 2004
    Mackay North Qld
    6,446
    The black oxide is applied typically to the end of Low Hyd. electrodes. It is to there start what are sometimes, difficult to cold start LH electrodes.
    The problem there is that the new LH rod leaves a bunch of porosity holes at the start of the bead. The correct way to start the rod is move downstream by a couple of stick diameters and strike the arc then snap back to the last bead crater area and match the ripple pattern. Correctly performed it is not easy for the untrained eye to pick the match up point.
    With a little practice it quite achievable. The (then downstream) porosities are then overcome by action of the now up to running temperature arc and particularly the excellent fluxing of that electrode type.
    The fluxing works so well one can often hear the arc "pop" and feel the spit out of an impurity out of the arc pool accompanied by some red hot slag and spatter.
    Heavy use of the LH electrode is a darn good reason to invest in a leather coat or at least some leather sleeves and apron.
    If using a low hydrogen electrode at home a striking plate helps. You can position it close to the restart, get the electrode arced and quickly while the electrode is still red hot nip over to the restart area and it will start for you,usually.
    Dec 2005
    South Australia
    1,656
    Thanks for the replies, seems as though there may have been some justification depending on his experience
    May 2020
    Wisconsin, US
    40
    13
    Talking
    Quote Originally Posted by Commander_Keen View Post
    Just be careful not to have the ground clamp attached to the file
    Dec 2018
    NSW
    586
    The old inappropriate preposition strikes again.
    With a file.
    Or I could just use a wood file.
  1. Stick Welding and slag
    By GSRocket in forum WELDING
    Last Post: 9th Mar 2014, 09:56 PM
  2. old stick welding m/c
    By gpigeon in forum WELDING
    Last Post: 27th Mar 2012, 07:06 AM
  3. Mug stick welding 8mm steel rod
    By Scally in forum WELDING
    Last Post: 12th Jul 2008, 11:23 PM
  4. What you always wanted to know about stick welding P1
    Last Post: 18th Dec 2007, 10:14 PM
  5. Stick Welding
    Last Post: 17th Sep 2007, 11:10 AM
