Results 1 to 10 of 10
Thread: Transtig 250EC Problems
20th May 2020, 10:58 PM #1New Member
- Jun 2014
- Perth Western Australia
- 2
Hi Guys. I have an old Transtig 250EC ,which is not behaving well.
The operator manual mentions in "maintenance" to remove the top cover and adjust the
"spark gap" every six months or so . Can any one advise where this adjustment is located ?
To me everything looks to be solid state.
Thanks,
valley.
21st May 2020, 09:24 AM #2Golden Member
- Jun 2005
- Helensburgh
- 618
23rd May 2020, 10:41 AM #3
Hi Valley
Welcome to the the Metalwork Forums.
Here is a guide to exploring our forum. Things including the rules Terms of Use may have changed and well worth keeping up with.
If you click on the down arrow in the FORUM box -Top LH corner
A pull down menu appears by clicking Forum Home.Forum Home and it takes you to a scroll -able page.
The Terms of Use -please read- them are right on top and the rest as you scroll down are help areas and sub forums . Some of the sub forums have stickies on top to guide the user.
We are privileged to have a group of helpful folk here.
Transtig 250EC
From memory there were a few separate Transtig 250 EC models. The majority are -large Esky, stood on its end size with castors.
- and the other were smaller (almost) portables. There were a bunch of variants.Google Transtig 250EC and select illustrations /pics to see what I mean.
Some of the metal cases had apertures covered by a screwed down cover plate a couple of inches square and others didn't. Those with no openings had solid state EC control and no user adjustable parts. Also consider that the manual may not be the right one for the machine you have.
aldwaker in 2011 asked a question in the forums about tracking down a board for a Transtig 250 EC.He received no reply other than Cigwelds phone number.
If you have no sheet metal covers on the external case you almost certainly have a solid state model,. If so best make friends with someone into circuit board repair.
please consider visiting the welcome wagon to introduce yourself and tells us about your metalworking. It is in the forum home scroll down page
Also you might change your location to a town or suburbs.It makes it easier for members close by to help if necessary.
Welcome to the mob
23rd May 2020, 06:49 PM #4Senior Member
- May 2013
- Rockhampton, QLD
- 68
- 454
Welcome to the forum.
23rd May 2020, 10:07 PM #5
I hope to offer you some valuable feedback.
The spark gap is accessible by removing the top cover.
Refer to the maintenance manual for the correct spark gap value.
23rd May 2020, 11:19 PM #6Most Valued Member
- Sep 2010
- Lebrina
- 1,910
28th May 2020, 05:23 PM #7New Member
- Jun 2014
- 2
Transtig 250EC
Hi Grahame:
Thank you for your welcome and very valid advice:
The machine I have , " large Esky Type " is solid state
and appears to have no spark gap adjustment. The problem
with it is virtually no amperage control in either "local" mode
using the amperage dial or "remote" mode using the foot control.
29th May 2020, 08:21 PM #8Senior Member
- Oct 2015
- melbourne
- 473
So is it running 'flat out' or 'minimum setting', when you say it has no adjustment?
30th May 2020, 05:16 PM #9
Hi Valley,
Could possibly take a picture of the front of the Transtig EC case showing the controls.?
Also another maybe another showings specs label usually on the back panel.
It will help a lot with ID of controls so we are all pulling on the same oar.
30th May 2020, 05:41 PM #10
Any lights, or fan noise,then?
Disregarding the spark gap adjustment for the moment, I would ask if the pedal plug is disconnected when the local mode of operation is attempted.
Could it be that the remote has an over ride function to prevent local operation when the pedal is connected and possibly that pedal unit is faulty ?
It could point to a problem in the amperage control circuit. Something that could be solved by cleaning or reconnecting .
Since you have only given QLD as a location we can't recommend a close by commercial repairer who might be able to diagnose the problem further.
This is why we encourage a more precise area location such as a suburb or a locality.
CIG Transtig 150
By GuzziJohn in forum WELDINGReplies: 41Last Post: 14th Sep 2020, 10:33 AM -
Looking for a welder manual, GIG/NZIG Transtig 250EC
By NZ1 in forum WELDINGReplies: 7Last Post: 23rd Nov 2019, 05:17 AM -
DONE: Transtig 275
By Barterbuilt in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 2nd Apr 2013, 07:00 PM -
tig welder PCB for 250EC CIG Tigmaster
By aldwalker in forum WELDINGReplies: 1Last Post: 11th May 2011, 03:39 PM -
FS: Transtig 180
By ISL33P in forum METALWORK GENERALReplies: 8Last Post: 25th Jun 2007, 10:10 PM
