Results 1 to 3 of 3
Thread: Smallest arc welder I've seen
16th May 2020, 12:27 PM #1Senior Member
- Nov 2019
- Brisbane
- 69
- 452
SAM_0638.jpgHello from BC.
This is the smallest arc welder I've come across. The grinding wheel is 125mm for comparison. I gave it a go with a 3.2mm 12P and what a pearler. Beautiful arc and stable, easy to strike. On 2.5mm rods it was hard to get going and needed to run hot to be stable. It could be I have a dicky unit. Well finished, good HD lead set and a digital amp meter. I will get another to see if this one is crook.
old Goat.
16th May 2020, 02:20 PM #2Diamond Member
- Aug 2006
- 1,106
I got a similar unit as well just to try out, it's rated as a 200A unit but it won't get anywhere near that. I run it near max setting and it works well, I have even tried to tig with it and had good results. Not bad for something that cost under $75. It's so light and compact, you can take it anywhere.
16th May 2020, 04:44 PM #3Most Valued Member
It's not as small as the one my father used to have, it was about 150 mm cubed, two terminals on it, and no adjustment for amps or anything else. It came with a carbon arc torch also. It was made by AEM from memory
World's Smallest 5 Axis Machine
By KBs PensNmore in forum CNC ForumReplies: 0Last Post: 5th Sep 2018, 01:23 AM -
QUEENSLAND Cig welder transarc tradesman HD (stick/arc welder) 3phase
By dkaoffroad in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 8th Jun 2013, 10:45 AM -
SOLD: CIG AC/DC tig welder
By RVK 355 in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 4th Jul 2012, 07:27 PM -
best welder for Gal?
By Danger Mouse in forum WELDINGReplies: 10Last Post: 14th Feb 2012, 06:31 PM -
Mig Welder
By China in forum WELDINGReplies: 0Last Post: 27th Dec 2009, 10:10 PM
