Results 1 to 11 of 11
Thread: Hirane AS100 240v v 415v help
3rd May 2020, 08:34 PM #1New Member
- May 2020
- 53
- 5
Hi All,
I know this is a long shot.
A long while back a acquired a Hirane AS100 (415v single phase) spot welder. I need to make use of it or move it on. I know they were available in a 240v single phase version.
I'm hoping both 415v and 240v use the same transformer. Looking inside I was hoping for some jumpers or links that just needed to be swapped over, but not so.
The primary side of the transformer looks like it has multiple taps, and is connected the the two outermost ones.
Any advice would be a help.
thanks
Dave
4th May 2020, 09:09 AM #2New Member
- May 2020
- 53
- 5
Photos
Hi All,
I have attached some photos as requested.
Also I pulled one of the covers off the one of spare transformer taps and it has a fitting on it ready to connect to a source.
thanks
Dave
4th May 2020, 03:17 PM #3Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,183
Simplest solution, just try to use a 25 or 30A 240v circuit, and run on the highest output setting.
Rewiring solution...
I can't quite make out the wiring on the primaries. Blow the dust out and check which ones are used. Looks like there are 4 taps, but lets assume for now there are 3?
Get a multimeter. Measure the primary's resistance across the two outermost taps (say 1 & 3).
Then measure 1 to 2, and 2 to 3.
If 1->2 equals 2->3, and that is half 1->3, then you might be able to reconfigure.*
It depends if tap 2 has two insulated wires from the transformer soldered into the terminal. It will be tricky.
* A trained transformer tech, or very experienced electrician should be used, but if you are brave and trust your circuit breakers and safety switches, tap 2 gets split and well insulated. 1=active, 2A=neutral, 2B=active, 3=neutral.Last edited by nigelpearson; 4th May 2020 at 03:22 PM. Reason: Put simplest option first
4th May 2020, 04:08 PM #4Diamond Member
- Jun 2010
- Canberra
- 1,322
It looks to use a single 415V phase, probably using the longest winding. At a (complete) guess, you could measure the resistance of that winding and then multiply it by 240/415 and see if you can find a tap that corresponds to that lower resistance.
It's likely that the control circuitry's power supply is designed for 415V, so there might be another small transformer you'll need to sort out.
(Edit: didn't see Nigel's response - I must have had this tab sitting open for a while...).
4th May 2020, 08:53 PM #5New Member
- May 2020
- 53
- 5
primary windings
Hi,
Thanks for your helpful responses.
I get the same resistance across each set of primary windings.
If divide the current power 415v across the four primary windings 103.75v each (415v, 311.25v, 207.5v, 103.75v)
Just making an assumption here, if this was a fairly generic transformer would it fair to assume is was used for 415v,???v,240v,110v
I have added a better photo of the primary winding connections, with the covers removed.
They all have connectors already fitted on them.
The two outermost smaller ones are the ones currently connected, with a capacitor across them.
The three larger middle ones are not used, they have two wires from the transformer in each.
thanks
Dave
4th May 2020, 09:55 PM #6
See renovate forum, but
Using the photo label the connectors A,B, C, D, E from right to left. Measure resistance A to B, A to C, A to D etc and post the values.
Yes it appears to be a multi tap transformer so can be used for multiple voltages. The end connectors are end taps and a single conductor, the other are intermediate taps with two conductors.
You may need to also alter any control system transformer settings but possibly leave them on the current taps when you move the primary connections. In this way the transformer will work in boosting mode to boost the voltage for the rest of the circuit.
4th May 2020, 10:20 PM #7New Member
- May 2020
- 53
- 5
A-B, B-C, C-D, D-E and A-E all measure 0.4
4th May 2020, 10:23 PM #8
Use a different scale to get better accuracy of resistance, it’s going to be low because it’s a high current circuit. Disconnect anything from E so you are not measuring outside influence aNd reference all to A, it is currently the common connection.
4th May 2020, 10:27 PM #9New Member
- May 2020
- 53
- 5
Hi Droog,
Also measured A-B, A-C,A-D,A-E and all were the same.
Unfortunately its the lowest setting on all my meters (200).
4th May 2020, 10:41 PM #10
Its a multi tap transformer and most likely will simply just need connecting to the correct transformer taps.
Unfortunately without wiring diagrams or suitable equipment to measure the winding you will probably need to take it to someone that has suitable equipment. I would suggest someone that does transformer or motor repair or rewinding.
4th May 2020, 10:48 PM #11
Another option that can be performed by a suitably trained technician is to connect to 415v and measure the voltage on each of the taps.
As this requires work on live equipment it should only be performed by qualified persons, we are talking about high voltage and high current equipment in this instance
415v three phase from 240v single phase a home made digital phase converter?
By lamestllama in forum ELECTRICALSReplies: 26Last Post: 20th Sep 2018, 07:35 PM -
240v 15a in 415v 3phase out - options?
By variant22 in forum METALWORK GENERALReplies: 34Last Post: 3rd Sep 2012, 07:13 PM -
240v single phase to 415v 3 phase conversion
By Oldneweng in forum METALWORK GENERALReplies: 81Last Post: 12th Jul 2012, 05:58 PM -
SOLD: vintage German made tool grinder 3 phase 240v &415v
By thorens in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 4th Jul 2012, 10:11 PM -
240V 1-phase to 415V 3-phase vfd
By neksmerj in forum METALWORK GENERALReplies: 23Last Post: 24th Dec 2010, 11:11 AM
