Results 1 to 4 of 4
    Apr 2020
    AU
    2
    Default Weldmaster tig 200
    Hi does any one know of service agent for weldmaster tig machines
    I believe they are Chinese built . This machine is as new and for no apparent reason just stopped working. It powers up but there is no response to the button on the torch . All setting are good as per previous use .
    Sent from my SM-T595 using Tapatalk
    May 2013
    Rockhampton, QLD
    68
    455
    Welcome to the forum. I’m sure someone will be able to help with your inquiry.
    Jan 2004
    Mackay North Qld
    6,446
    Hi,
    I did a google search and found this on Machines4U.
    It is not looking promising. Maybe a phone call to them may yield more info.
    Weldmaster AC:DC 200 Tig copy.jpg
    Sep 2010
    Lebrina
    1,915
    Unfortunately I can confirm that Weldmaster went belly up some years ago. On the bright side, they are/were a very generic Chinese machine so most repairers will be able to tackle them - I (and it's a big if) they want to and most don't because the labour cost quickly exceeds the value of the machine. I suggest checking the simple things such as broken trigger wiring and faulty plugs and switches as an opening move and then moving to more invasive measures if that doesn't put the heartbeat back into the machine.
  1. Weldmaster TIG 200p ???
    By blkcrx in forum WELDING
    Last Post: 15th Dec 2007, 04:47 PM
