Results 1 to 8 of 8
28th Apr 2020, 03:36 PM #1New Member
- Apr 2020
- Australia
- 5
Ozito MWR - 135 -- Welding current but no motor or feed
I picked this welder off the side of the street a couple years ago and have only just gotten round to having a look at it.
So far I've:
- Fixed the CR1 relay and checked to make sure CR2 is functional.
- Tested the feed motor with a 12v battery and confirmed that it does indeed feed
The high current welding circuit is working fine, but the motor does absolutely nothing. I measured the voltage coming into the feed regulation from pins 2 and 5 but I only get 3V when the welder is set to a voltage other than 0v. on 0, I only measure areound 2.5V.
Any ideas?
28th Apr 2020, 06:43 PM #2
From the way I read that circuit pins 2 and 5 are the external DC supply to that circuit, therefore your external power supply is faulty.
28th Apr 2020, 11:00 PM #3New Member
- Apr 2020
- Australia
- 5
Right. I'll have a look tomorrow and see if I can find anything suspicious.
29th Apr 2020, 12:23 AM #4
Look for simple things first.
If the gun cable is a permanent connection , try the trigger switch mechanism. Check the mechanical on off function and then the electrical function.
Can't speak for machines these days but years back the trigger, or trigger cable connections were a common source of failure.
A real rrsole trick was to wrap one of the connector pins (on an industrial unit) in sticky tape, when someone went for smoko.
When they came back Voila! the mig wouldn't work
29th Apr 2020, 01:44 AM #5Most Valued Member
- 5,945
Grahame, that's nearly as bad as black cardboard in the welding mask. This was prior to the auto darkening helmets.
29th Apr 2020, 12:54 PM #6New Member
- Apr 2020
- Australia
- 5
Well, I checked the voltage on the board input again and i now measure 30v. So that seems to be working now. I also checked the voltage across the CR2 relay and found that there was only around 4.2v even though the transformer seems to be outputting 7v when under load. CR1 seems to work fine but CR2 just won't trigger. I used a 12v battery to activate the coil on CR2 and found that the feeding worked. I did have to rewind CR1 with a slightly thicker wire to get it to work. Maybe the coil is drawing more power than it originally did?
29th Apr 2020, 01:14 PM #7New Member
- Apr 2020
- Australia
- 5
Ok, I did some calculations and I'm pretty sure this is the problem. The rewound relay only has 7.2 ohms of resistance where as the CR2 relay has 400 ohms.
29th Apr 2020, 02:20 PM #8New Member
- Apr 2020
- Australia
- 5
After doing some more testing I belive this is the issue. I'm just going to buy a suitable replacement on ebay and hope it works. Thanks for all the help, guys!
Ozito MWR-135 help needed please
By ausdier in forum WELDINGReplies: 6Last Post: 24th Oct 2018, 12:22 PM -
Engage/disengage feed levers while feed rod is rotating al960b
By Ben Dono in forum METALWORK GENERALReplies: 8Last Post: 11th Sep 2012, 08:11 PM -
TIG welding gas flow and current
By Pete F in forum WELDINGReplies: 13Last Post: 7th Sep 2009, 11:16 PM -
welding old saw bench with electric motor attached ..
By Gedmet in forum WELDINGReplies: 2Last Post: 22nd May 2009, 10:28 PM -
ozito 90 Amp Mig Welder
By Gaza in forum WELDINGReplies: 23Last Post: 9th Dec 2008, 04:06 PM
