Results 16 to 18 of 18
Thread: 3 axis welding clamp
12th Feb 2020, 05:40 PM #16
Any welder worth its salt in a specialised production environment welding to code will have the ability to lock out or at least limit parameters available to the operator.
Some are even going to LAN based data logging to assist welding supervisors with ensuring that metrics are being met within these available parameters.
The days of 2-dial Timmy who only uses 1 setting for whatever he is welding and won't be told otherwise, are numbered.
14th Feb 2020, 01:07 PM #17Most Valued Member
- Sep 2010
- Lebrina
- 1,915
The newer technology certainly goes some way to mitigating the effects of operators that cannot or will not adhere to a procedure sheet. Unfortunately we do not yet have the technology to adjust attitudes, so these same souls will find other areas to spread their superior knowledge and derail the job.
And they wonder why robots seem such an attractive option?
14th Feb 2020, 08:55 PM #18Most Valued Member
We've a 220 amp CIG three in one welder at work, and I'm befuddled when it comes to setting it up. I know I'm old but this new technology is getting beyond me.
I remember welding Cyanide pots, 1" thick material, 6" fillets, it was a Ranby welder that I was using, with rods as thick as my thumb, and the choke sat about a metre and a half away from it. It ran for several days like that. Them was the days.
KANT-TWIST Round Handle Clamp 3/4", Clamp Mfg 396
By DSEL74 in forum METALWORK GENERALReplies: 7Last Post: 10th Aug 2019, 08:05 AM -
Y Axis Way Cover
By Oldneweng in forum METALWORK GENERALReplies: 1Last Post: 24th Jul 2016, 01:33 AM -
5 axis machining
By Enfield Guy in forum METALWORK GENERALReplies: 11Last Post: 19th Apr 2012, 01:25 AM -
Z Axis DRO fittment
By eskimo in forum METALWORK GENERALReplies: 12Last Post: 5th Jan 2010, 07:37 PM -
Z axis protection
By John H in forum METALWORK GENERALReplies: 16Last Post: 10th Feb 2009, 08:32 PM
